ENGINE REMOVAL... QUCIK QUESTION
Old May 8, 2004 | 02:44 PM
khmboostedeh2's Avatar
Default ENGINE REMOVAL... QUCIK QUESTION
where and how do i attach the engine hoist to the engine?
Old May 8, 2004 | 03:41 PM
doublejz's Avatar
Default Re: ENGINE REMOVAL... QUCIK QUESTION (Jeterkm02)
i have wrapped a chain the whole way around the block, used motor mounts, used the hook where the manifold bolts to and the rear bracket.
Old May 8, 2004 | 06:30 PM
Kamin's Avatar
Default Re: ENGINE REMOVAL... QUCIK QUESTION (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">i have wrapped a chain the whole way around the block, used motor mounts, used the hook where the manifold bolts to and the rear bracket.</TD></TR></TABLE>
there is a threaded hole in the back of the head on the drivers side (14mm bolt) put a large bolt on there with the chain attached. run the other chain to the transmission. there SHOULD be a gold colored bracket thats pretty obviously got a setup for a hook to go on it. run the chain down to it then attach it with a bolt and a nut.
that is the "proper" way honda reccomends.
Old May 8, 2004 | 10:48 PM
kur0ryu's Avatar
Default Re: ENGINE REMOVAL... QUCIK QUESTION (Kamin)
It's best to get at least 3/4 attachments going. behind the head, transmission bracket, and there should be one on the front of the block near where the exhaust attaches....
Old May 14, 2004 | 09:57 AM
lcopas's Avatar
is it possible to remove the engine without removing the transmission (manal trans)
Old May 14, 2004 | 11:45 AM
-Trinitron-'s Avatar
Instead of a chain, we use a heavy duty tow rope with the clips on it. You can just unscrew one of the tranny bolts and clip the hook to it. Same thing on the other side. The rope doesn't scratch up the head either.
Old May 14, 2004 | 12:36 PM
doublejz's Avatar
Default Re: (-TRINiTRON-)
i have/seen people use seatbelts before
Old May 14, 2004 | 12:39 PM
Kamin's Avatar
Default Re: ENGINE REMOVAL... QUCIK QUESTION (lcopas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lcopas &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to remove the engine without removing the transmission (manal trans)</TD></TR></TABLE>
it is easier with the transmission installed.
EG9_Sedan
Jul 20, 2015 08:28 PM
Slacker93eg
Jul 28, 2012 02:23 PM
oem_certified_accord
Sep 20, 2007 06:06 PM
civickiller
Aug 16, 2005 09:15 AM
SEA Hag
Nov 20, 2002 05:59 PM
