which head gasket and timing belt for b20vtec?
Old May 8, 2004 | 01:54 PM
Rob!'s Avatar
Default which head gasket and timing belt for b20vtec?
hey guys i have a 00 b20z motor and i am putting my 94 gsr head on it. what head gasket and timing belt do i need? i searched and i only see people with bigger bores and stuff. i have a stock b20z block. anyone know? only answer if your 100% sure. thanks a lot
Old May 9, 2004 | 06:51 AM
Rod.'s Avatar
Default Re: which head gasket and timing belt for b20vtec? (EKsnatchback)
you will need a 84mm headgasket...oem will work. Go with a gsr timing belt
Old May 9, 2004 | 08:22 AM
mmuller's Avatar
Mad Scientist
Default Re: which head gasket and timing belt for b20vtec? (redturbocivic)
you need to get the timing belt depending on the water pump you use...
ls water pump(19t)=ls t belt
vtec water pump(22t)=gsr timing belt
Old May 9, 2004 | 11:40 AM
Rob!'s Avatar
Default Re: which head gasket and timing belt for b20vtec? (mmuller)
i am using the b20 waterpump so im assuming im using the b20 timing belt and head gasket. is this correct?
Old May 9, 2004 | 03:49 PM
N20civicB18's Avatar
that is correct
Old May 9, 2004 | 04:17 PM
tinkerbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKsnatchback &raquo;</TD></TR><TR><TD CLASS="quote">i am using the b20 waterpump so im assuming im using the b20 timing belt and head gasket. is this correct?</TD></TR></TABLE>
no, it is not.
if you are going to rev past 7000 you need a 22 tooth (VTEC) water pump or you will probably overheat your engine.
you need a VTEC belt witha the VTEC pump.
Old May 9, 2004 | 04:33 PM
ExospeedAMcrx's Avatar
agree... never do a Vtec conversion without changing the Oil Pump to GSR/ITR pump.
Guaranteed your b20vtec wont last long if you stick with stock non-vtec oil pump.
Old May 10, 2004 | 07:22 PM
tinkerbell's Avatar
Default Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">agree... never do a Vtec conversion without changing the Oil Pump to GSR/ITR pump.
no - i am actually talking about the water pump.
i think that the B20Z shares the same oil pump as the B18CR anyways, so you are wrong.
92f22a6
Mar 8, 2014 06:26 PM
SolAssassin
14
Oct 2, 2009 03:09 PM
fro
Dec 21, 2004 12:56 PM
hondeducation
Feb 5, 2004 11:56 AM
Norcalstoppy
Aug 7, 2003 01:13 PM
