Car won't idle with 550s and basemap
Old May 8, 2004 | 11:28 AM
93dx--hatch's Avatar
Default Car won't idle with 550s and basemap
Went to start up my car today ( gsr motor, 2000 type R head, sidewinder, t3/t04e, hks wastegate,blah blah), and it was rich, really bad
The idle was all over the place between 750 and 900, shitty throttle response in nuetral,
I bought a hondata s200b and 550s with a basemap, I am starting to think that they sent my a bad map, its smoking real bad at idle.
anyone have another 550cc basemap???
What should i do hear
Edit I do have a walbro 255lph fuel pump as well
Old May 8, 2004 | 11:34 AM
Sohc Driver's Avatar
Default Re: Car won't idle with 550s and basemap (93dx--hatch)
basemaps..typically aren't perfect...its just so that you can get your car on the road to a dyno and get tuned.
Khoi
Old May 8, 2004 | 11:37 AM
Default Re: Car won't idle with 550s and basemap (Sohc Driver)
yeah but this is bad, like at idle it smokes soooo bad, its dumping way too much fuel, all the plugs are wet,
I couldn't get to the tuner if he lived 2 minutes away from me, I smoke out my nieghborhood every time i start it
Old May 8, 2004 | 12:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93dx--hatch &raquo;</TD></TR><TR><TD CLASS="quote">yeah but this is bad, like at idle it smokes soooo bad, its dumping way too much fuel, all the plugs are wet,
I couldn't get to the tuner if he lived 2 minutes away from me, I smoke out my nieghborhood every time i start it</TD></TR></TABLE>
hmm..are you sure the basemap is set for 550s?
Khoi
Old May 8, 2004 | 02:08 PM
TurboJesse
Guest
Posts: n/a
what kind of 550's? i had the same problem and it ended up being my injectors.
Old May 8, 2004 | 02:20 PM
Default Re: Car won't idle with 550s and basemap (Mpir3)
they are brand new rc injectors, with 0bd1 clips
Old May 8, 2004 | 02:32 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93dx--hatch &raquo;</TD></TR><TR><TD CLASS="quote">they are brand new rc injectors, with 0bd1 clips</TD></TR></TABLE>
ok...just making sure you didn't get some of the infamous 550's sold by viren
Old May 8, 2004 | 04:35 PM
D@nnY's Avatar
turn down your fuel pressure and get it tuned...turn up the idle with the screw on the throttle body ..let it idle at 900-1100 ..check for vac leaks
hai_tech
19
Mar 20, 2007 07:26 PM
MATiC
Dec 2, 2006 07:26 PM
Layziebtnh055
Aug 31, 2004 03:07 PM
sydag5
Mar 26, 2003 08:42 AM
