Are my motor mounts from a 95 GSR complete for JDM B16a Sir2 swap?
Old May 8, 2004 | 09:01 AM
handa's Avatar
Default Are my motor mounts from a 95 GSR complete for JDM B16a Sir2 swap?
Just got my motor mounts/brackets from a 95 GSR for my JDM B16A SiR2 but not sure if that's all I need.
According to the picture below, I'm not sure if it's complete enough for my swap because it looks like I got only 2 mounts and 3 brackets. I know these motor mount questions are confusing sometimes.
-Seller: nutzurchin02 on AIM
-Parts from 95 GSR, going into 93 civic 4dr w/ JDM B16a sir2
Old May 8, 2004 | 09:03 AM
xavior66's Avatar
Default Re: Are my motor mounts from a 95 GSR complete for JDM B16a Sir2 swap? (handa)
I'm almost positive you can use the #3 engine mount.
Old May 8, 2004 | 10:09 AM
743power's Avatar
Default Re: Are my motor mounts from a 95 GSR complete for JDM B16a Sir2 swap? (xavior66)
#1 is the AC compressor bracket/lower torque mount
#2 is the rear motor mount
#3 is the timing belt side upper mount
#4 is the tranny mount
#5 is the tranny torque mount
So, yes, you did get all of the mounts.
Old May 22, 2004 | 11:11 AM
function83's Avatar
Default Re: Are my motor mounts from a 95 GSR complete for JDM B16a Sir2 swap? (x743x)
im sure to use motor mount #3 your gonna need the bracket that goes with it.
the one that mounts to the block from a dc.
if your swap is out of eg6 they use the stock steel mount out of 92-95 civics on the upper driver side. *if your single cam uses a black upper steel mount use that instead of #3.
mount #4 you can reuse off your single cam.
Old May 22, 2004 | 11:31 AM
EGsixer's Avatar
i wasnt able to use a integra mount #3 for my b16 swap, i dont think that one will work. In my 92-95 hatch i had to use the del sol DOHC vtec rear mount..
Old May 22, 2004 | 11:33 AM
Echo7847's Avatar
Default Re: Are my motor mounts from a 95 GSR complete for JDM B16a Sir2 swap? (djhatch)
Got em all, you're good to go get swapping
Old May 22, 2004 | 07:38 PM
nevamind's Avatar
Default Re: Are my motor mounts from a 95 GSR complete for JDM B16a Sir2 swap? (Echo7847)
#3 is not needed for B16, you can use the stock civic upper driver side mount if this motor is going into 92-95 Civic. Trust me I came across this many times
Old May 22, 2004 | 07:50 PM
92civeg's Avatar
the posts on the bracket need to be even with each other, the posts on my single cam mount weren't, so i had to buy the integra bracket too, although i don't know if all single cam mounts posts are diagonal
this was my single cam mount, that didn't work because of the diagonal posts
and this is what i had to buy to be able to bolt it up to my b16a( note the design of the posts)
blueskiesfade609
Oct 27, 2005 02:59 PM
SLow-Side
Apr 7, 2005 01:54 PM
97civicdx
Feb 9, 2005 12:32 PM
c.u.one
Jul 12, 2004 05:33 PM
gear
Oct 10, 2003 07:30 PM
