SOHC SPARK PLUG WIRE FIRING ORDER!!!
Old May 8, 2004 | 07:19 AM
jaycapz's Avatar
Default SOHC SPARK PLUG WIRE FIRING ORDER!!!
Ugh! I have a 2000 honda civic LX - (Engine is D16Y7 i believe, SOHC)
The car starts, then trys to die after hitting the gas. RPM's drop like crazy, and it runs like crap! I was thinkin distributor or alternator. The battery is fully charged though! Running at over 14V idle, and 13.1V with AC and lights on. Very strange.
Im thinking the wires are crossed, and its miss-firing. It sounds a lil "putty" at the tail pipe. I let my friend do my wires while I was at work cause the car was feeling like crap, and i didnt have the time.
Here is how its wired:
someone else posted this for DOHC i think, but this is how mine is wired!
Desperate! Anybody?
Update: Here is the diagram from a Haynes book (for D16Y7 Motor):
I just dont know how to read it:
Thanks again
Modified by jaycapz at 5:08 PM 5/8/2004
Modified by jaycapz at 5:41 PM 5/8/2004
Old May 9, 2004 | 12:22 AM
underrated's Avatar
Default Re: SOHC SPARK PLUG WIRE FIRING ORDER!!! (jaycapz)
It's correct. Make sure they're plugged in good.
Btw what were you doing to you car, or did it just happen??
Old May 9, 2004 | 12:48 AM
Reason's Avatar
firing order should be 1-3-4-2.
Old May 9, 2004 | 01:21 PM
jaycapz's Avatar
Default Re: (Reason)
Basically, the car just started to feel like it was having a serious loss of power.
I didnt do anything to it at all. Its been gradual for about 3 weeks or so now.
all wires are in good.
I dont know what to do.
Old May 9, 2004 | 06:41 PM
Eclpze97's Avatar
Default Re: (jaycapz)
hey i had a problem with my d16y8 and i lost alot of pwer and turned out it was a clogged cat, but for missfiring try new plugs wires distributor cap and rotor.... hope this helps
Old May 10, 2004 | 06:41 AM
jaycapz's Avatar
Default Re: (Eclpze97)
Highly doubt its a cat issue though. its a 2000 with only 40K miles on it. then again, ya may never know!
it feels more like an electrical problem though to be honest.
Old May 10, 2004 | 07:05 PM
Eclpze97's Avatar
i thought the same thing, my 2000 with 44k, does it sound normal, or does it sond like its just not right, how about when ur on the freeway does it move when ur at like 50 trying to go fast?
Old May 12, 2004 | 03:44 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reason &raquo;</TD></TR><TR><TD CLASS="quote">firing order should be 1-3-4-2. </TD></TR></TABLE>
This is correct, your original diagram of the firing order is wrong
Old May 12, 2004 | 07:02 PM
Iceman05's Avatar
did your timing get off? mine did=no power!
Old Jun 6, 2004 | 03:33 PM
sergantfalcon's Avatar
Thanks Man! I was looking for the firing order for my DOHC engine, and found your question about you plug wire. When you said that you thought it was the DOHC wiring order, I printed your picture and ran out to my Accord to try it out. Sure enough, it fired right up! Because of that I've joined this website just to thank you. This was a definite headache for me.
Matthew
Old Jun 6, 2004 | 03:39 PM
EIT_certified's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaycapz &raquo;</TD></TR><TR><TD CLASS="quote">
It sounds a lil "putty" at the tail pipe[/i]</TD></TR></TABLE>
check your timing
Tippyman
13
Apr 11, 2006 09:05 AM
JDMTRSPORTS
Oct 8, 2005 01:14 PM
jaycapz
12
May 8, 2004 09:11 AM
Gump
May 10, 2002 12:19 PM
EL-Driver
Apr 13, 2002 04:56 PM
