catch can question.
Old May 8, 2004 | 06:46 AM
jbell's Avatar
Default catch can question.
wow, for something so simple.. this sure is confusing.
im thinking of fabbing up my own catch can.. can you guys tell me if this is a decent design? its for an n/a application, i just want to avoid putting all that oil back into my intake...
i figure i'll drain it every time i change my oil.. say... 5k miles...
here is the design of the actual can:
now heres my questions: i searched, but couldn't find them.
1: what screen material will work best? can i use window screen? the soft kind or the metal?
2: lets say i accumulate 1/2 quart of oil in my can.. that means my engine is running 1/2 quart low... how bad is this nessicarily?
3: now where the hell do i hook this up? do i go out on the valve cover and back in on the intake manifold? or do i go out on the back of the block and in on the intake manifold... im really confused here. pictures would REALLY help here.
thanks guys.
Old May 8, 2004 | 07:46 AM
spaceman's Avatar
Default Re: catch can question. (jbell)
are you tryin to replace the pcv system(black box and hoses) on the back of the block?..or..are you just wanting to add your own catch can?
Old May 8, 2004 | 07:50 AM
jbell's Avatar
Default Re: catch can question. (spaceman)
im not sure. i just want to avoid sprayng the oil back into my intake manifold.. just keeping it all cleaner.
im not exactly sure of the benifits other than that.
Old May 8, 2004 | 08:45 AM
spaceman's Avatar
tube goes from valve cover to your catch can then from the catch can to the intake tubing(not the intake manifold,thats for the pcv system)..its pretty simple dood...good luck
Old May 8, 2004 | 03:07 PM
teglsturbo's Avatar
you dont need screen at all, i used a mountain dew can and ran a piece of fuel line from the valve cover to it, works great and its lightweight, doesnt need to go back to intake thats just for emissions purposes, actually you will still get oil vapors in the intake if you run it back to the intake even from a catch can, oil vapors cause detonation, you can even run a little more timing after you do this
Old May 16, 2004 | 01:13 PM
the_0ne's Avatar
Default Re: catch can question. (teglsturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teglsturbo &raquo;</TD></TR><TR><TD CLASS="quote">you dont need screen at all, i used a mountain dew can and ran a piece of fuel line from the valve cover to it, works great and its lightweight, doesnt need to go back to intake thats just for emissions purposes, actually you will still get oil vapors in the intake if you run it back to the intake even from a catch can, oil vapors cause detonation, you can even run a little more timing after you do this</TD></TR></TABLE>
Can i see pics of this ghetto mod? heh sounds interesting
Old May 16, 2004 | 01:24 PM
98-tag's Avatar
Default Re: catch can question. (the_0ne)
yes sir
Old May 16, 2004 | 03:33 PM
eg_type_r93's Avatar
the benifits of not dumping the oil into the intake manifold are higher octane (fuel that is) putting oil down their will reduce your fuels octane thats why its not good to put it in their
but its bad for the enviroment if you vent it into the atmosphere
Je8021
21
Aug 10, 2010 11:08 AM
thomas188
Oct 7, 2006 05:28 PM
yellowmonkeyboy
Oct 30, 2003 04:33 PM
It's Blue
Mar 15, 2002 10:31 AM
90accord1
Dec 13, 2001 06:58 PM
