How to keep flywheel still while removing it?
Old Nov 4, 2001 | 08:48 PM
boomslang's Avatar
Default How to keep flywheel still while removing it?
I wish I had air tools right now. Is there any cheap way to keep the flywheel still so I can take it and the clutch off? Honda wants $120 bucks for their flywheel holder.
Old Nov 4, 2001 | 09:11 PM
advanracing62's Avatar
Default Re: How to keep flywheel still while removing it? (Inlinefour)
just take a pry bar and put a bit of pressure on the back of the wheel. That's what I had to do the first time I took it off. Or you could use a 2x4 shortened and push it against the side of the wheel the wood won't mess up the wheel.
Old Nov 5, 2001 | 12:09 AM
Blown90hatcH's Avatar
Default Re: How to keep flywheel still while removing it? (advanracing62)
Stick a screw driver through one of the holes of the flywheel so that it hits the block and wont move. That or you can always hold the crank pully bolt with a big socket and breaker bar.....
Schultzie
Jan 16, 2008 09:41 AM
jdm_vtec
Feb 13, 2007 11:36 AM
.Thomas
Jan 16, 2007 10:45 PM
integraautox
Dec 24, 2003 06:14 PM
blazin
Jan 19, 2002 07:48 PM
