Engalls in Front, Ghetto Rig in rear - just did tonight, got questions
Old May 7, 2004 | 08:46 PM
kevinoneill's Avatar
Default Engalls in Front, Ghetto Rig in rear - just did tonight, got questions
i hit this post in the CRX forumn too, but i'm crunched for time and need some info.
I placed the engalls (adjustable .75 -> 3 in the front ok, some bolts were hard as **** to take out...but its in ok.
In the rear, i went for the "washers per every inch drop" theory. I hear you have replace the bolt though with a longer one? is that true? absolutely necessary?
I could only do the bolts on one side as one nut on the rear left is being a bitch and i'll have to have it air/impacted off. But when i drove it up and down the street the car pulled pretty strong to the right side. Could the washers being absent in the rear left be doing this? or do you think maybe i messed up the settings on the adjustable ball joints (the camber kit).
Getting worried about it.
Old May 7, 2004 | 09:04 PM
Sliced Beard's Avatar
Default Re: Engalls in Front, Ghetto Rig in rear - just did tonight, got questions (issues4)
you dont need a camber kit in the rear at all
the key to not having inner tire wear with a lowered vehicle is the <FONT SIZE="4"><FONT COLOR="red">ALIGNMENT</FONT></FONT>
if you do not have a good alignment then you will have excessive tire wear
all you need to do in order to prevent inner tire wear is get an alignment
Old May 7, 2004 | 10:03 PM
Default Re: Engalls in Front, Ghetto Rig in rear - just did tonight, got questions (dirtyd463)
hmmm ok well i'm ditching the washers in the rear and getting it aligned tom. then
let me ask you this. if i did not make all the camber kits camber exactly the same...will the alignment be pointless until i get it correct?
Old May 8, 2004 | 06:09 AM
any good alignment shop should know how to adjust a camber kit
just tell them to adjust camber in the front to -1 degrees and leave the rear alone and just to a toe and go after adjusting the front camber
and -1* is within factory spec so do not worry about it, you do not want your camber set at 0 unless you drive like grandma
Old May 8, 2004 | 10:45 AM
mmuller's Avatar
Mad Scientist
yeah, what eats your tires and making your car pull is the toe, as far as the rear, i used 1 washer with a 1.8 drop and left my rear camber PERFECT at -.07
Old May 8, 2004 | 07:21 PM
Default Re: Engalls in Front, Ghetto Rig in rear - just did tonight, got questions (mmuller)
did you by chance use a longer stud with the washers or no?
Old May 8, 2004 | 08:23 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by issues4 &raquo;</TD></TR><TR><TD CLASS="quote">did you by chance use a longer stud with the washers or no?</TD></TR></TABLE>
there is no need unless you use like..3 or more, for 1 or2 washers stock bolt is fine
Old May 9, 2004 | 09:34 AM
well , i have no idea why. But the toes on my front right is pointing outwards big time. The camber on both adjustable ball joints are even set to the same setting. I'm lost.
And more problems. My koni yellow on the front left seems to have frozen. Any ideas how i fix that? it doesn't move at all.
Old May 10, 2004 | 06:15 AM
ttt - ahh help
Old May 12, 2004 | 05:39 PM
Fixed!
well apparently it was the camber kit killing the shocks. i reduced the engalls to its lowest setting and the shocks are working again. kinda odd i know...but perphaps too much camber was causing them to push against something. fyi: engalls 1.25 - 3.00 set to 1.25. It fixed the bad toe i was having on the front right aswell. SWEET!
zachhart12
Honda Fit
Mar 27, 2011 06:34 AM
EK_B
Dec 24, 2007 06:21 PM
kevinoneill
11
May 12, 2004 07:02 PM
FerioVtec94
Apr 25, 2004 01:50 PM
p0pe
May 22, 2002 06:30 AM
