Suspension Question? Please Help!
Old May 7, 2004 | 08:17 PM
life sux die's Avatar
RIP 1032
Default Suspension Question? Please Help!
Ok, Here's my question. I recently picked up some KG/MM Race Springs for my EG Hatch. The spring-rates are 8.6k (473lb) for the front, and 6.4kg (352lb) for the rear. For some stupid reason I assumed the place I was getting them from could get me KG/MM Short-stroke Dampers, Turns out they can't. So now I'm left not knowing what to get. I'v read alot of good things from people on here about Koni/Neuspeed Yellows. What's the difference between the 2? What's the highest spring-rate these struts can handle? The KG/MM springs will drop the car about 50mm (2 inches) so i want something that will be able to handle these springs with no problem. If you have any insight to my problem or know of other struts that will work let me know. TIA!
Old May 7, 2004 | 08:49 PM
REDGEAR's Avatar
Default Re: Suspension Question? Please Help! (life sux die)
I personally got the Koni/Neuspeed. The difference is that the Koni Sport Yellows are the universal ones and the Koni/Neuspeed are matched spring rate with the Neuspeed springs. I'm running mine with Neuspeed Sport Springs. Pretty much Koni made them specifically to the specs Neuspeed wanted. Also the have 5 grooves vs. 3 grooves.
Old May 7, 2004 | 08:58 PM
RIP 1032
Default Re: Suspension Question? Please Help! (REDGEAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDGEAR &raquo;</TD></TR><TR><TD CLASS="quote">I personally got the Koni/Neuspeed. The difference is that the Koni Sport Yellows are the universal ones and the Koni/Neuspeed are matched spring rate with the Neuspeed springs. I'm running mine with Neuspeed Sport Springs. Pretty much Koni made them specifically to the specs Neuspeed wanted. Also the have 5 grooves vs. 3 grooves.</TD></TR></TABLE>
cool deal. you wouldn't happen to know what the highest springrate is they can handle would you?
Old May 7, 2004 | 09:02 PM
REDGEAR's Avatar
Sorry no. I didn't look into the spring rates since I matched mine all Neuspeed and mine is a daily driver. Ride is so smooth though, at least I can vouch for that
Old May 7, 2004 | 09:47 PM
RIP 1032
bump for the night crew
help me out guys.
Old May 9, 2004 | 12:40 PM
RIP 1032
Old May 9, 2004 | 01:06 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDGEAR &raquo;</TD></TR><TR><TD CLASS="quote">I personally got the Koni/Neuspeed. [b]The difference is that the Koni Sport Yellows are the universal ones and the Koni/Neuspeed are matched spring rate with the Neuspeed springs. I'm running mine with Neuspeed Sport Springs. Pretty much Koni made them specifically to the specs Neuspeed wanted. Also the have 5 grooves vs. 3 grooves.</TD></TR></TABLE>
The Neuspeed/Konis have a 20mm shorter shaft and the 5 grooves instead of 3. That's it.
Valving is the exact same.
Old May 9, 2004 | 01:09 PM
REDGEAR's Avatar
Default Re: Suspension Question? Please Help! (SkyeC)
I guess I got pnwed lol. I'll just sit in the corner then
Old May 9, 2004 | 01:59 PM
RIP 1032
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">The Neuspeed/Konis have a 20mm shorter shaft and the 5 grooves instead of 3. That's it.
Valving is the exact same.</TD></TR></TABLE>
the 20mm shorter shaft is for what? to help the shock from "bottoming-out"? these grooves are for what?, is that for damper control?
Old May 9, 2004 | 03:21 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
shorter shaft is there to limit droop. nothing else. if you're running short springs, it'll keep 'em from flopping around. bout it.
grooves are there for adjustable spring perches for normal springs. lets you play around with the height a little.
Old May 9, 2004 | 03:28 PM
RIP 1032
fresssh. i went ahead and ordered some Neuspeed/Koni Yellows SP3
thanks guys!
Razor
Honda S2000
14
Aug 20, 2004 05:19 PM
life sux die
May 9, 2004 02:28 PM
nfiedler3
19
May 16, 2003 02:12 PM
Rratedcivichatch
25
Sep 18, 2002 03:35 AM
dumbchild
Jun 12, 2002 11:02 AM
