k20 compression?
how does the ITR K20 raise compression to 11.5:1 over the type s 11.0:1??
pistons? head gasket? head?
the head and block are the same castings right?
thanks
also i just saw that with the usdm pistons + the toda head gasket = 11.4:1
so what else is different from the ITR to the usdm type s?
IM, header and cams right? Is that all?
you guys actually have it backwards, the k20a has stiffer single valve springs, and the older type-s had dual valve springs, while the newer models are starting to use single valve springs like the k20a.
type-s has the same dual valve springs on the intake side as the s2k ( i believe )
2fknlo
Feb 20, 2002 10:13 PM
