Engine overheats while driving but not at idle??
Old May 7, 2004 | 01:48 PM
ScrapinSi's Avatar
Default Engine overheats while driving but not at idle??
I've got to head over to a buddy's house tomorrow... he has a 92 DX w/ a b16a2 in it that he recently swapped... He said that its overheating while driving now.... He tried both his mugen thermostat and his OEM thermostat, and same thing... It doesn't overheat while idling, only while driving... He says there are no air pockets in the cooling system... Suggestions?
Old May 7, 2004 | 01:55 PM
ABK's Avatar
ABK
Default Re: Engine overheats while driving but not at idle?? (ScrapinSi)
Check compression, check oil for coolant, check collant for oil, does the exhaust smell funny, going waterpump, radiator is too small.
Old May 7, 2004 | 01:57 PM
HUBB's Avatar
Default Re: Engine overheats while driving but not at idle?? (ABK)
i was having issues with overheating and it turned out to be my radiator cap was too small and not releasing pressure properly and my fan was no turning on when supposed to so i wired up a manual switch.....i havent overheated since....also check what was mentioned above...goodluck man
Old May 7, 2004 | 02:01 PM
HUBB's Avatar
Default Re: Engine overheats while driving but not at idle?? (HUBB)
also feel the lower radiator hose to make sure coolant is passimg through into the motor....it should be warm but not hot as the upper should be... if its cold u could have an air pocket still
Old May 7, 2004 | 02:09 PM
ScrapinSi's Avatar
he says the fan IS working correctly... I'm not sure what radiator cap he has...
Old May 7, 2004 | 05:29 PM
ScrapinSi's Avatar
had him try to run it without a t-stat and still heated up... DOesn't heat up if you rev it at a stop and hold it, only under load..
I do remember hearing a noise sounding like a bad bearing coming from the timing belt... He said it was the Timing belt tensioner, but now that I think about it, sounds like he has the timing belt too tight and it may have fubar'd the water pump... Possibly?
Also, his radiator was sitting outside for a year before he installed it, so it could be all clogged up... But I'm thinkin its the water pump.
Old May 10, 2004 | 03:33 PM
HUBB's Avatar
just go over everything
Old May 10, 2004 | 05:06 PM
ScrapinSi's Avatar
fixed it... dumbass was having a problem with his fan plug when he did the swap, so he hard wired the fan, and wired it backwards... dumbass... I swapped the wires and BADA BING! Much better...
Old Oct 10, 2016 | 07:42 AM
Rebeccabearo9's Avatar
I have a 2001 honda civic lx I have the head shaved new gaskets it still over heats the fan only comes on when the a.c. is on it only over heats when driving while its idling its fine doesn't get hot or anything?? Does anyone know why it still over heats
Old Oct 10, 2016 | 09:31 AM
chrysler kid's Avatar
Yes, your radiator fan is broken.
I'm not familiar with your generation civic but the 1992-2000 civic has 2 fans, one for the ac and one for the radiator. If your fan is only functioning with the ac there is a problem with the fan either receiving power, or turning on
Old Oct 10, 2016 | 02:36 PM
other than the ac what tells the fan to turn on?
Old Oct 10, 2016 | 03:53 PM
Former User's Avatar
Honda-Tech - Announcements in Forum : Honda Civic / Del Sol (1992 - 2000)
dsands7
Aug 21, 2012 10:29 PM
E_F_9
10
Jun 18, 2012 08:14 PM
snzh22
Oct 1, 2006 03:06 PM
civicmatt
13
Sep 25, 2003 11:40 AM
99 HXagon
Jul 21, 2002 09:13 AM
