distributor problems i think
Old May 7, 2004 | 01:47 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default distributor problems i think
ok heres the deal now when i am driving my car on the street it all of a sudden looses power and the tach starts to bounce around and and the car starts to spudder a little and some times dies and will not start for a minute. now my question is has any one else had a simular problem and what was there findings
and to i have a msd ignition too and i tested it and its working properly or could the msd coil be going bad is this a sign of a bad coil or just bad ignitor or just a fucked up dizzy period. and right now i am waiting on a friend to bring me a stock coil so i can test to see if it still or does not have the same problems with the ignition being turned all the way back too stock
Old May 7, 2004 | 06:38 PM
JO3's Avatar
JO3
Default Re: distributor problems i think (streetdreams02)
same problem here with no solution yet..
and my car idles pretty high at times too..
i've been plugging the iacv fuse out, wait 10s and put it back..
then it runs fine again...for q while that is..
still trying to find out whats the problem...
good luck and do let me know if u manage to solve the problem..
thanks...
Old May 7, 2004 | 07:45 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
most likely it is a failing igniter, replace it. check your spark plugs as well, i had some high RPM misfire when i installed my MSD cap, wires and coil, ended up being my spark plugs being burned by the increased voltage.
stan
Old May 8, 2004 | 08:11 AM
Default Re: distributor problems i think (Stan D)
bump anyone else and thanks stan d and stan what kind of plugs are u useing now
Old May 8, 2004 | 06:59 PM
JO3's Avatar
JO3
hey streetdreams02,
just wondering, how often does your car hunts when u drive and does your car idles really high at times?...
also..when your car hunts, what do u do to make it run properly again...
i'm having the same problem as well..car hunts and idling is really high at times...
and i'm still thinking if i should get a new iacv...
as they all say thats the problem...
checked all other possibilities and nothing was faulty...
thanks..joe
Old May 9, 2004 | 08:21 PM
Default Re: (JO3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JO3 &raquo;</TD></TR><TR><TD CLASS="quote">hey streetdreams02,
thanks..joe</TD></TR></TABLE>
what the hell are u talking about what is hunts. and w/ my car i know my problems is either the ecu or the dizzy because i am haveing a problem with spark not idling
Old May 9, 2004 | 09:57 PM
JO3's Avatar
JO3
well..by hunting i mean the car loses power and the rpm will increase and drop rapidly while your legs on the accelerator...
but looks like we're on different problem...
good luck fixing your problem..
joe
Old May 10, 2004 | 06:52 AM
Default Re: (JO3)
ok
Old May 10, 2004 | 06:58 AM
4door-r's Avatar
Default Re: (streetdreams02)
same problem im replacing my distirbutor tonight. and wires
Old May 10, 2004 | 01:24 PM
RobbieG35's Avatar
12 Years Strong
Default Re: (4door-r)
My car did the same thing, but it ended up jumping time No bent valves though, jumped about 5 teeth on the exhaust cam
Old May 10, 2004 | 07:20 PM
backdraft's Avatar
I would say it was your distributor... My friends car did the same thing and we changed the distributor and everything was good after that... Hope this helps...
Old Jun 5, 2004 | 07:22 PM
OneOver's Avatar
i have been experiencing similar problem - as if the engine has got mind of ist own! Anyway, have you found the solution? Would really help me to know how you solved the problem. Thanks.
Old Jun 6, 2004 | 07:05 AM
woodog's Avatar
bad ignitor in the distributor.
replace it, or you can get a whole new distributor from a h-t sponsor(dist. king) for the same price.
Old Jun 6, 2004 | 07:13 AM
hotintegranights's Avatar
Default Re: distributor problems i think (dc2R320)
everysingle thing you said happen to me after like a month of driving with the msd w/coil , i just removed the msd and car is fine now.
oh btw the guy i sold the msd to started having the same problems after a week or so, i think the msd just puts too much stress on the stock ignitor.
Old Jun 6, 2004 | 05:09 PM
Default Re: distributor problems i think (hotintegranights)
hey i just pulled of the msd and the problem went away
playalistic2
Aug 22, 2005 09:13 AM
96b18c
Dec 28, 2004 11:31 AM
ithrowpoop
Nov 25, 2002 05:30 AM
