dohc vtec solenoid. any way to convert JDM one to 2 wire?
Old May 7, 2004 | 09:18 AM
B_CRUZ!'s Avatar
Default dohc vtec solenoid. any way to convert JDM one to 2 wire?
Is there a way to convert the one wire JDM dohc solenoid to US spec?
Old May 7, 2004 | 01:45 PM
hadehatch's Avatar
Default Re: dohc vtec solenoid. any way to convert JDM one to 2 wire? (b cruz)
The VTEC solenoid on all DOHC bseries engines are one wire.. Are you talkin about the pressure switch??
Old May 7, 2004 | 01:46 PM
ABK's Avatar
ABK
Default Re: dohc vtec solenoid. any way to convert JDM one to 2 wire? (hadehatch)
yeah the two wire thing is vtec pressure switch, one wire thing is the vtec solenoid.
Old May 7, 2004 | 01:54 PM
hadehatch's Avatar
Default Re: dohc vtec solenoid. any way to convert JDM one to 2 wire? (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">yeah the two wire thing is vtec pressure switch, one wire thing is the vtec solenoid.</TD></TR></TABLE>
and even then you only need one wire since you can ground that switch to the head as well..
Old May 7, 2004 | 01:56 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadehatch &raquo;</TD></TR><TR><TD CLASS="quote">
and even then you only need one wire since you can ground that switch to the head as well.. </TD></TR></TABLE>
yep
Old May 10, 2004 | 09:56 AM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadehatch &raquo;</TD></TR><TR><TD CLASS="quote">The VTEC solenoid on all DOHC bseries engines are one wire.. Are you talkin about the pressure switch??
so the jdm pressure switch only has one wire?
only reason I am asking is because my vtec isn't working with a USDM ecu. I have a JDM motor.
Old May 10, 2004 | 10:23 AM
Nextelbuddy's Avatar
hmm i have seen a few jdm motors that dont come with vtec pressure switches on the motor because they are built into the ECU. when i had a jdm itr swap it didnt come witha oil pressure switch i had to go to acura and buy one. but i could have used a jdm ecu with no problems but i wanted to use the usdm ecu.
Old May 10, 2004 | 10:24 AM
B_CRUZ!'s Avatar
Default Re: dohc vtec solenoid. any way to convert JDM one to 2 wire? (NextelBuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NextelBuddy &raquo;</TD></TR><TR><TD CLASS="quote">hmm i have seen a few jdm motors that dont come with vtec pressure switches on the motor because they are built into the ECU. when i had a jdm itr swap it didnt come witha oil pressure switch i had to go to acura and buy one. but i could have used a jdm ecu with no problems but i wanted to use the usdm ecu.</TD></TR></TABLE>
so thats what I need. can you post a picture of it?
Old May 10, 2004 | 11:07 AM
splitime's Avatar
You can use the jdm one without a problem. Just use a helms and find the to pin locations where the pressure switch and solenoid come into the usdm ecu, then run a jumper wire between them.
At least thats what is done with mine and it works perfectly.
No reason to buy usdm vtec stuff, or any other parts honestly.
Old May 10, 2004 | 11:21 AM
B_CRUZ!'s Avatar
Default Re: dohc vtec solenoid. any way to convert JDM one to 2 wire? (splitime)
perfect thats what I needed to know...
Old May 10, 2004 | 01:37 PM
ABK's Avatar
ABK
You should of stated your problem correctly. You were talking about the solenoid when you really ment that there was no vtec pressure sensor(switch).
Old May 10, 2004 | 01:44 PM
B_CRUZ!'s Avatar
problem was, I didn't know what my problem was.
there is a vtec pressure switch. vtec just doesn't work with the usdm ecu.
Modified by b cruz at 3:04 PM 5/10/2004
Old May 10, 2004 | 04:27 PM
hadehatch's Avatar
if you dont have a pressure switch just ground the wire going to it and it will override it..
Old May 11, 2004 | 12:40 PM
B_CRUZ!'s Avatar
still no vtec
checked the oil, wiring, vtec solenoid... now I gotta borrow a ECU.
Old May 11, 2004 | 03:24 PM
hadehatch's Avatar
wire it up temporarily to a switch.. or you can connect a multimeter or led to the vtec signal wire and see if the ecu gives out a signal..
this way you can see if its the ecu or something on the engine thats not working properly..
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadehatch &raquo;</TD></TR><TR><TD CLASS="quote">wire it up temporarily to a switch.. or you can connect a multimeter or led to the vtec signal wire and see if the ecu gives out a signal..
this way you can see if its the ecu or something on the engine thats not working properly.. </TD></TR></TABLE>yeah i'll try that tonight
Old May 12, 2004 | 08:24 PM
ABK's Avatar
ABK
do you get any CELs?
Old May 12, 2004 | 09:41 PM
Daryl_SP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b cruz &raquo;</TD></TR><TR><TD CLASS="quote">still no vtec </TD></TR></TABLE>
Byron, if you still can't troubleshoot it......you can always do VTEC-Killers
B_CRUZ!'s Avatar
nope. my guess is the ECU is bad.
I am waiting for some local friends of mines to let me test their ECU on my car
*cough* *cough*
Old May 13, 2004 | 08:53 AM
cre18's Avatar
lol damn, i get the hint. come by the house tonight.
Old May 13, 2004 | 08:26 PM
B_CRUZ!'s Avatar
Default Re: dohc vtec solenoid. any way to convert JDM one to 2 wire? (cre18)
found out the chipped p28 ECU is shitty. Its a real p28 and its chipped but when I compared it to Cre18's p28, I have a few resistors missing Looks like it was never there.
Used his ECU and BAM! vtec hit.
Old May 13, 2004 | 08:54 PM
degooser's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b cruz &raquo;</TD></TR><TR><TD CLASS="quote">found out the chipped p28 ECU is shitty. Its a real p28 and its chipped but when I compared it to Cre18's p28, I have a few resistors missing Looks like it was never there.
Used his ECU and BAM! vtec hit. </TD></TR></TABLE>
damn that shop and them giving you that wack *** ecu....
it did seem weird to me that i was able to interchange my usdm ecu with my girls jdm ecu....
Old May 13, 2004 | 09:00 PM
B_CRUZ!'s Avatar
Default Re: dohc vtec solenoid. any way to convert JDM one to 2 wire? (degooser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser &raquo;</TD></TR><TR><TD CLASS="quote">
word... they 'said' it will be resolved. I just need to drop it off to take care of the other issues.
JSPECSIR
Oct 7, 2008 06:56 PM
Civic97s
Aug 14, 2006 09:28 AM
jcektyper
Jan 2, 2006 06:38 AM
mr. carpenter
May 5, 2004 09:47 PM
delslow94
May 20, 2003 07:37 AM
