Revhard with bunch of other goodies, but are the goodies necessary?
Old May 7, 2004 | 09:13 AM
ThePro's Avatar
Default Revhard with bunch of other goodies, but are the goodies necessary?
Hey there. I've done some research into FI for my 95 GS-R and I've found a kit that I like. But I don't know too much about some of the other goodies he wants to sell me. Assuming that I will never up the boost, are these goodies necessary or "nice" to have with this setup running either .4 bar (5.75 psi) or .5 bar (7.2 psi). It will be tuned to be reliable. I realize boost and reliable are oxymoron's when we are talking Honda's, but... Fuel management will be taken care of by AEM EMS or Hondata.
1) Missing Link Check Valve
2) RC Engineering 310cc Injectors
3) MSD Sport Compact Ignition & MSD Distributor Cap & MSD Blaster 2 Coil
I'm pretty sure from what I've read that a Missing Link is always nice to have.
The Injectors, I'm not sure about. The RevHard kit doesn't come with upgraded injectors so why would I need them? Would it be an extra precaution or something?
I've also read that Ignition is a good thing to have when boosting. But if I'm only running 7 psi do I really need it?
In case you haven't figured out, I'm trying to "value engineer" the kit and bring the price down a bit.
Old May 7, 2004 | 09:21 AM
quikB18B's Avatar
Default Re: Revhard with bunch of other goodies, but are the goodies necessary? (ThePro)
1) You won't need a missing link with hondata/Ems
2) you'll need bigger injectors, besides im sure youll grow enough courage to tune to 9-10 psi by the time it comes. Either way dont get the 310cc injectors
3) For your goals an Ignition is not necesarry.
Ideal setup would be 550cc Rc's/hondata and 9-10 psi
If your determined to keep the boost low, im sure some 440cc's would be fine.
Old May 7, 2004 | 09:30 AM
ThePro's Avatar
Default Re: Revhard with bunch of other goodies, but are the goodies necessary? (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">1) You won't need a missing link with hondata/Ems</TD></TR></TABLE>
Okay. Thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">2) you'll need bigger injectors, besides im sure youll grow enough courage to tune to 9-10 psi by the time it comes. Either way dont get the 310cc injectors</TD></TR></TABLE>
I assume that is because the 310 are just slightly bigger than stock hence a waste of money, is that correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikb18B &raquo;</TD></TR><TR><TD CLASS="quote">3) For your goals an Ignition is not necesarry.</TD></TR></TABLE>
For what goals would an ignition become necessary? At what horsepower level?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikb18b &raquo;</TD></TR><TR><TD CLASS="quote">Ideal setup would be 550cc Rc's/hondata and 9-10 psi
If your determined to keep the boost low, im sure some 440cc's would be fine. </TD></TR></TABLE>
The boost will stay low because I don't want to spend the money to make it faster. But if you think that 550cc would improve my reliability then I'm all for 550cc.
Old May 7, 2004 | 01:21 PM
ThePro's Avatar
Okay, did a little more research. Going with the 550s because they are only like $20 extra.
Still trying to figure out about the ignition. So far, I've read that you have to retard the timing without upgraded ignition, but with ignition you don't have to retard.
True or untrue?
secondz
Mar 30, 2012 08:18 PM
unknown0304
Jun 8, 2004 10:17 PM
yellow blur
Mar 26, 2003 08:43 AM
speeds
Jun 10, 2002 09:23 PM
97integraLST
Nov 13, 2001 12:06 PM
