Can you put a B16 LSD in a USDM LS tranny?
Old May 6, 2004 | 08:59 PM
Del_Slowest's Avatar
Default Can you put a B16 LSD in a USDM LS tranny?
Can you take the SIR2 B16 LSD's and put them in any B series tranny's or can they only go in the B16 tranny's?
Old May 6, 2004 | 09:00 PM
Default Re: Can you put a B16 LSD in a USDM LS tranny? (Del_Slowest)
here's a picture of an LSD
Old May 6, 2004 | 09:13 PM
phthalo's Avatar
GDD4LIFE
Default Re: Can you put a B16 LSD in a USDM LS tranny? (92SIvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92SIvic &raquo;</TD></TR><TR><TD CLASS="quote">i BELIEVE so..</TD></TR></TABLE>
Old May 6, 2004 | 09:18 PM
sshaikh01's Avatar
you can even put LS tranny on there too.
Mostly all B series parts are interchangable
Old May 7, 2004 | 09:43 AM
60-1c1's Avatar
Default Re: Can you put a B16 LSD in a USDM LS tranny? (sshaikh01)
it will work
Old May 7, 2004 | 10:19 AM
eg6ajk's Avatar
this looks like a KAAZ or some other LSD.
92-00 JDM LSDs from a B16a usually have 12 bolts on the FD, which does not work or interchange but this is different so it looks to be aftermarket or Teg diff, which uses the proper : 10bolt pattern
Old May 7, 2004 | 10:27 AM
Race Egr's Avatar
Default Re: Can you put a B16 LSD in a USDM LS tranny? (eg6ajk)
you can but i think you need the countershaft fromt the b16 tranny also
Old May 7, 2004 | 12:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">this looks like a KAAZ or some other LSD.
92-00 JDM LSDs from a B16a usually have 12 bolts on the FD, which does not work or interchange but this is different so it looks to be aftermarket or Teg diff, which uses the proper : 10bolt pattern</TD></TR></TABLE>
you're very good. it is a KAAZ LSD, i just put a picture in here so ppl would look at the thread. i'll look tonight and see if it's a 12 bolt, if it is then i'm screwed....right?
stalyun
Southeast (Sales)
Oct 19, 2009 08:14 PM
MI4$DC5
May 18, 2005 12:11 PM
AudioXtremes
May 22, 2002 09:09 AM
