ahhh quick question. coilover problem..!!
Old May 6, 2004 | 08:57 PM
tyflip2's Avatar
Default ahhh quick question. coilover problem..!!
ok i just installed some coilovers onto my kyb agx and i lowered the front down off the jack and it sits really high. so i jacked it back up to adjust the coilovers and i set them almost on their lowest settings and it still sits too high. i mean like an inch gap. do i need to cut something off the front struts to lower the car a little more. it is rediculous. please help quick. thanks
Old May 6, 2004 | 08:59 PM
From: eating the shit out of pizza in raleigh, NC, USA
Default Re: ahhh quick question. coilover problem..!! (tyflip2)
make sure the strut is sitting in properly on the bottom...
Old May 6, 2004 | 09:00 PM
tyflip2's Avatar
Default Re: ahhh quick question. coilover problem..!! (2ndchancehonda)
yeah i checked everything and the coilover is sitting on the strut. i cut the plastic covering but is there something else i need to do to make it go lower?
Old May 7, 2004 | 10:03 AM
make sure that the actual strut assembly is sitting all the way in that metal bracket in the bottom, over the axle...
Old May 7, 2004 | 10:12 AM
Andres-eh2's Avatar
make sure its going into the top hat
Old May 7, 2004 | 12:45 PM
tyflip2's Avatar
Default Re: (Andres-eh2)
problem solved. there was a metal sleeve on the strut that would not slide over the threads on the coilover, instead it was hitting the top where the threads bugun instead of dropping down to where i had it adjusted. thanks for the help
Throwback23
13
Apr 15, 2009 07:47 PM
Hyb
Suspension & Brakes
Jan 15, 2005 09:07 AM
null.
Aug 20, 2004 07:42 PM
DJ_SaNdOz
Mar 26, 2003 12:42 PM
SEIKI
May 20, 2002 04:48 AM
