Boosting problem
I'm getting a white cloud of smoke in back of my car when I boost it. Off boost its fine. I this this problem for two days now. I was driving home from work I and I boost it and when I look out my rear view mirror its smoke city. when I let off it the smoke goes right away. off boost the car drives fine. no oil in the coolant. My breather hose is laying on my tranny. anyone got any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesi00 »</TD></TR><TR><TD CLASS="quote">turbo seals??</TD></TR></TABLE> If its a water cooled turbo then possibly.
Check your head gasket, have the car running and look for bubbles in the radiator when the cap is off... also sheck your oil for signs of coolant... good luck
Like Derek said, it's probably a blown headgasket. Does it overheat at all when it idles for awhile after driving? Any signs of coolant blowing out the overflow?
no. it never overheats. I checked the coolant and oil and it non in either. its a oil only turbo.
I did notice something today though while I was reving the motor. the turbo return flange gasket is leaking. its actually smoking a little from there. whel I rev the motor at 4-5000 RPM I can see oil trying to come out of the flange seal. I thought it was a straight flow from the return to the oil pan. oil shouldn't have time get up there.
EtherEG93
Sep 17, 2005 08:18 PM
greekspeed
Sep 26, 2004 06:02 AM
