b20 or itr crank
Old May 6, 2004 | 08:05 PM
drunknbass's Avatar
Default b20 or itr crank
whats the power loss from using itr crank in a b20 vtec compared to the b20 crank..
im wondering if its worth it to run an itr crank for more relaibility and slightly higher revs (supposedly)
im thinking the engine will still be just as prone to failure as it would be with the b20 crank .
i know itll have a better r/s ratio.. butttt. i dont know if its worth it..
Old May 6, 2004 | 08:43 PM
Propulsion's Avatar
Default Re: b20 or itr crank (drunknbass)
what block?
Old May 6, 2004 | 08:47 PM
drunknbass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass &raquo;</TD></TR><TR><TD CLASS="quote">whats the power loss from using itr crank in a b20 vtec ..</TD></TR></TABLE>
Old May 7, 2004 | 04:27 PM
Propulsion's Avatar
look up Omniman's gsr cranked b20vtec dyno, definitely worth it to put a 87mm crank in there if money is not a issue. It will cost a lot more though with the crank, rods, pistons, and machine work
Old May 7, 2004 | 05:23 PM
drunknbass's Avatar
Default Re: b20 or itr crank (SilverCIVIC96)
i was already swapping out pistons and rods for some so all id really be paying more than i would before is what id buy the crank for.
plus toda makes pistons for b20 blocks with itr/gsr cranks so if toda is actually supporting that setup it must be good
Old May 8, 2004 | 04:46 PM
drunknbass's Avatar
bizzump
Old May 9, 2004 | 05:18 AM
All Toda Dc2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass &raquo;</TD></TR><TR><TD CLASS="quote">i was already swapping out pistons and rods for some so all id really be paying more than i would before is what id buy the crank for.
plus toda makes pistons for b20 blocks with itr/gsr cranks so if toda is actually supporting that setup it must be good</TD></TR></TABLE>
Toda's pistons will work w/ b20/ls rods too.
I'd stick w/ the 89mm crank (b20/ls).
Not worth theb money and loss of hp/tq & displacement for .03 higher of a r/s ratio.
Run a girdle, arp main studs/ Head studs/ rod bolts, vtec oil/water pumps. You'll be good.
Old May 9, 2004 | 02:02 PM
drunknbass's Avatar
Default Re: b20 or itr crank (All Toda Dc2)
i thought you couldnt run a girdle on a b20 block.. they only fit gsr itr blocks? or am i wrong
Old May 9, 2004 | 02:22 PM
All Toda Dc2
Guest
Posts: n/a
Endyne makes a girdle, GE has a full girdle kit w/ new, windage tray, oil pickup, & main bolts too, or you can run a modified itr/gsr girdle.
Old May 9, 2004 | 06:04 PM
drunknbass's Avatar
any idea what the ge kit runs?
Old May 9, 2004 | 10:48 PM
All Toda Dc2
Guest
Posts: n/a
Contact Tom from 'Camp1320.com' on this board.
He's badass.
AMR Engineering
Northwest (Sales)
Sep 16, 2007 03:21 PM
camlob
Apr 22, 2006 11:18 PM
5w20
Dec 4, 2004 11:57 PM
vtec_racer_2kgsr
Nov 19, 2003 07:36 PM
XSBoost
Jun 12, 2001 10:46 AM
