car starts then dies...code 7
Old May 6, 2004 | 05:00 PM
hondaeg8's Avatar
Default car starts then dies...code 7
car starts and idles fine. then it just dies out and turns off. check engine light is on and its code 7.
what needs to be done? tps is bad or just needs to be adjusted?
Old May 6, 2004 | 05:15 PM
Jimmy's Avatar
Global Moderator
You are correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECU Codes &raquo;</TD></TR><TR><TD CLASS="quote">7 TPS - throttle position sensor </TD></TR></TABLE>
Replace your TPS and reset your ECU by removing the negative battery terminal for 5-10 minutes OR pull your ecu fuse for 2-3 minutes
Goodluck and get back to us
Old May 6, 2004 | 06:10 PM
hondaeg8's Avatar
Default Re: (Usdmdc2)
i've replaced the tps sensor twice and even changed tb with my friend. still same code.
BanditSiR
May 3, 2007 11:54 AM
skiracer8148
Aug 2, 2006 03:26 AM
imlachg1
16
May 22, 2004 06:04 PM
Civic89
Jun 19, 2002 04:49 PM
