HELP: Tranny fluid is leaking through Half-shaft
Old May 6, 2004 | 03:21 PM
JapJunkie's Avatar
Default HELP: Tranny fluid is leaking through Half-shaft
I just put in a new tranny, and after filling it w/ oil it started leaking though the half-shaft. I know i need a new Axel Seal but is this difficult to replace??? Im looking for Good Advice here. Thanks in Advance yO Any info is good info.
Old May 6, 2004 | 03:51 PM
Echo7847's Avatar
Default Re: HELP: Tranny fluid is leaking through Half-shaft (hOnDadiCt)
Easy to replace, just pop out the axle/shaft and you can pop out the seal with a flathead and put the new one in, they're cheap as well.
Old May 6, 2004 | 03:53 PM
Ricey McRicerton's Avatar
I'm in the same boat as you. I'll be replacing mine this weekend.
https://honda-tech.com/zerothread?id=849171
Old May 6, 2004 | 08:27 PM
JapJunkie's Avatar
Default Re: HELP: Tranny fluid is leaking through Half-shaft (Ricey McRicerton)
alright cool thanx, Should i use any type of i guess gasket sealent?
Old May 6, 2004 | 09:22 PM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOnDadiCt &raquo;</TD></TR><TR><TD CLASS="quote">alright cool thanx, Should i use any type of i guess gasket sealent?</TD></TR></TABLE>
You can rub a bit of RTV around the edge with your finger if you want, but its not necessary. All you need is a screwdriver to pry the old one out, then use a block of wood and a hammer to bang the new one in.
Old May 6, 2004 | 10:00 PM
sohcvtec1995's Avatar
Default Re: HELP: Tranny fluid is leaking through Half-shaft (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
You can rub a bit of RTV around the edge with your finger if you want, but its not necessary. All you need is a screwdriver to pry the old one out, then use a block of wood and a hammer to bang the new one in.</TD></TR></TABLE>
yup you dont need any sealent. just pop out the old one and put in the new one.
Old May 10, 2004 | 12:26 PM
Blacklightning's Avatar
how do you check the level of your tranny fliud?
Old May 10, 2004 | 12:31 PM
Risky Business
Default Re: (Blacklightning)
Take out the fill plug, stick your finger in and if you feel fluid right below the hole you are good.
phish4709
Apr 8, 2007 07:51 PM
EG2Driver
Nov 1, 2006 07:23 PM
Discontained
22
Oct 16, 2006 02:07 AM
Cheeech
16
Nov 16, 2005 06:27 PM
