installed gsr dash now blinkers dont work
Old May 6, 2004 | 12:15 PM
rtiadnoh's Avatar
Default installed gsr dash now blinkers dont work
has anyone else in here install a gsr dash? i put it in and got everything but the blinkers and speedo to work. also my windshield wipers keep on wiping all the time and it is making my alarm act stupid and keep me from starting the car. do anyone else has these similiar problems.
Old May 6, 2004 | 12:34 PM
JDMH22HATCH's Avatar
Default Re: installed gsr dash now blinkers dont work (rtiadnoh)
GSR Dash into EG wiring information:
Using the GSR harness (which I have done), it's very simple to get your dash 100% working.
You can use the GREEN and BLUE plug, which plug right into the Civic fuse box plugs.
HOWEVER
The grey plug has additional pinouts on the Integra dash harness and cannot be used. Just retain the Civic grey plug and match the pinouts.
I am currently making a JPEG diagram for this -- will be up soon.
ONE THING, your turn signals will not work.
Why?
This is why:
The power wire going to the Integra hazard switch is the Yel/Blk wire, where-as the Civic hazard switch is the YEL wire.
Just simply take the Yel/Blk wire from the Integra harness (which is an unused wire from the grey plug), and splice that into the Yel wire on the GREEN plug (the middle pinout YEL wire.
Kaboom -- done.
/\ Courtesy of Poison aka Brandon
shivic
Aug 2, 2005 06:03 PM
12secondclub
Apr 2, 2004 09:07 PM
b16ferio
Feb 24, 2004 08:35 AM
