96 integra dash in 95 civic?
Old 03-31-2004, 06:23 PM
12secondclub's Avatar
Default 96 integra dash in 95 civic?
i have a 95 civic coupe, and i want to put an integra dashboard in..but i have heard of it being done, but never seen it done...anybody have any tips or could help me out about puting it in..or advice
Old 03-31-2004, 06:34 PM
JDMH22HATCH's Avatar
Default Re: 96 integra dash in 95 civic? (12secondclub)
Here's some info on the wiring from Brandon aka Poison
GSR Dash into EG wiring information:
Using the GSR harness (which I have done), it's very simple to get your dash 100% working.
You can use the GREEN and BLUE plug, which plug right into the Civic fuse box plugs.
HOWEVER
The grey plug has additional pinouts on the Integra dash harness and cannot be used. Just retain the Civic grey plug and match the pinouts.
I am currently making a JPEG diagram for this -- will be up soon.
ONE THING, your turn signals will not work.
Why?
This is why:
The power wire going to the Integra hazard switch is the Yel/Blk wire, where-as the Civic hazard switch is the YEL wire.
Just simply take the Yel/Blk wire from the Integra harness (which is an unused wire from the grey plug), and splice that into the Yel wire on the GREEN plug (the middle pinout YEL wire.
Kaboom -- done.
Other than that, just take your time. I used the civic dash mount and just used my dremel to trim out behind the guage cluster and the inside by the dash mounts. Here's some pics of mine in my 4-door. Everything lines up great except for the inside where right where the door closes towards the body and still its only a small gap
Old 03-31-2004, 06:39 PM
JdmCIVIC853's Avatar
I have an Integra Dash (complete), I will trade your for your civic dash complete....
Old 04-01-2004, 08:12 PM
Default Re: 96 integra dash in 95 civic? (JDMH22HATCH)
what about door panels?
Old 04-01-2004, 08:55 PM
kingSfit's Avatar
looks great
Old 04-01-2004, 09:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12secondclub &raquo;</TD></TR><TR><TD CLASS="quote">what about door panels?</TD></TR></TABLE>
I will not be running door panels or anything so I'm not really concerned with that. But if you do run civic door panels, you can take a heat gun to the crease until the are able to get spongy enought to close the doors and they will mold to the dash
Old 04-02-2004, 01:27 PM
ecksman's Avatar
i have the dash out so far but i dint know if i have to use the teg or civic heat boxes
Old 04-02-2004, 01:50 PM
drewbie*'s Avatar
Default Re: 96 integra dash in 95 civic? (JdmCIVIC853)
[/quote] I have an Integra Dash (complete), I will trade your for your civic dash complete.... [/quote]
where are you located?
Old 04-02-2004, 02:32 PM
703_Sleeper's Avatar
Default Re: 96 integra dash in 95 civic? (Drew95eg)
i have that dash in my car and everything works 100% even the turn signals. My friend did it for me. If you need his info let me know. Northern VA area.
Old 04-02-2004, 09:07 PM
hair_rice's Avatar
doors will not close with panels...you have to mod them with something...u can use a heat gun and heat heat the panels up and mould them to fit the dash...search around u can find instructions on how to do that
rtiadnoh
05-06-2004 12:34 PM
b16ferio
02-24-2004 08:35 AM
hadehatch
01-30-2004 03:19 PM
Quick Reply: 96 integra dash in 95 civic?
