Which oil in D16Y7???
Old May 6, 2004 | 11:44 AM
EK45VTi's Avatar
Default Which oil in D16Y7???
Hi!
I changed my oil few days ago and I used Shell Helix 10w40...
I'm not very happy with this oil despite the fact that I always used that and was happy until this one... it seems like it is bottled somewhere else and not Shell factory...
Would 5w30 be good enough for my car and which one do you propose?
The car was driven using Shell Helix 10w40 from the first day the car was bought... that's 8 years and 80.000 miles... will my car have any problems if I change viscosity from 10w40 to 5w30???
I do not race but I also do not drive my car like a woose... Anything below 4500 rpm is not exceptable in most cases so I drive 5500 majority of time except long journeys...
I change my oil every 4000 miles and every time I change the oil filter too (Honda OEM)...
Engine is stock D16Y7... which is the best oil for it???
Old May 6, 2004 | 11:47 AM
menkio's Avatar
Default Re: Which oil in D16Y7??? (KKVTi)
mobile 1 5w30 brotha
Old May 6, 2004 | 11:49 AM
JDM-97CX's Avatar
Default Re: Which oil in D16Y7??? (DewMota)
Amsoil
Old May 6, 2004 | 11:54 AM
EK45VTi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">mobile 1 5w30 brotha</TD></TR></TABLE>
That's what I was thinking too... and I think it will be Mobil1... just want to hear what others have to say about it...
My friend has Amsoil in his Mustang and is very satisfied with it... But Mobil1 is just more "out there"...
Old May 6, 2004 | 11:56 AM
GSR-Civic's Avatar
I also use mobile 1 5w30
Old May 6, 2004 | 12:01 PM
vtecb20coupe's Avatar
B A N N E D
whoa, you're in alaska. so the temps are different up there. the helms manual says 5w30, just depending on your conditions.
Old May 6, 2004 | 12:03 PM
Ricey McRicerton's Avatar
Default Re: Which oil in D16Y7??? (vtecb20coupe)
I run the Mobil1 SuperSyn 5w30 in the winter and 10w30 in the summer.
Old May 6, 2004 | 12:26 PM
EK45VTi's Avatar
Default Re: Which oil in D16Y7??? (Ricey McRicerton)
So you guys think that there will be no problem if I use 5w30 after 80.000 miles of continuos using of 10w40???
Old May 6, 2004 | 12:27 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi &raquo;</TD></TR><TR><TD CLASS="quote">So you guys think that there will be no problem if I use 5w30 after 80.000 miles of continuos using of 10w40???
No.
Old May 6, 2004 | 12:40 PM
a1320honda's Avatar
Default Re: Which oil in D16Y7??? (JDM-97CX)
castrol syntec 5w30
Old May 6, 2004 | 12:44 PM
RyanEJ8's Avatar
Pennzoil 10w-30.
Old May 6, 2004 | 03:39 PM
97dxnut's Avatar
Default Re: Which oil in D16Y7??? (RyanCivic2000)
I ran dino 10w40 for as long is i know in my civic for 75k. switched to 5w30 mobil 1, and runs great, no leaks.
Old May 6, 2004 | 04:07 PM
Kista20's Avatar
Default Re: Which oil in D16Y7??? (97dxnut)
when I first got my car I used castrol 5w30 for a while, I had always used castrol in the first couple cars I had then I used mobil 1 in the next 3 vehicles but when I got my honda I switched back to castrol cause I was tight on money and the mobil 1 was a lot more expensive. Now I'm using the mobil 1 5w30 and I have used that for over 60,000 miles, car has 145,000 miles now and I have had no problems whatsoever. Mobil 1 and Castrol are both great oils.
Old May 6, 2004 | 04:44 PM
a1320honda's Avatar
Default Re: Which oil in D16Y7??? (Kista20)
im not saying anything bad about anyone at all, but ive seen first hand what pennzoil does to dsm's, and its not pretty. i dont know if its the same for hondas, but dsm's and pennzoil do not mix.
george34
24
Sep 10, 2006 06:51 PM
coupon
Aug 28, 2005 12:19 PM
peel17
Jun 28, 2005 01:10 PM
integraboi1010
Sep 15, 2004 11:31 AM
io_burn
Dec 30, 2002 05:01 PM
