New to Stick Shift
Hi,
I have an 04 RSX-S (bought in Mar 04) and I want to know if I'm messing up my transmission in any sort of way. When the temperature is cold I have trouble shifting from 2nd to 3rd... for some reason the car likes to stay BETWEEN neutral and 3rd causing a grinding/ slipping noise, then when I press the clutch in again and push to 3rd it goes in.
Am I supposed to put a lot of force in the shift when the car is cold, or is something wrong with the gearbox/transmission already? It's easy to shift when its hot outside.
Any insight would be appreciated, thanks.
-Vouth
-Vouth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vouthanack »</TD></TR><TR><TD CLASS="quote">Hi,
-Vouth</TD></TR></TABLE>
if you search for 2nd gear im sure lots n lots of rsx topics will pop up for you
Make sure you are pressing it in all the way
jnb0111
Dec 1, 2015 11:23 PM
