Shift grinds
Old Feb 1, 2004 | 12:35 PM
fw190bvi's Avatar
Default Shift grinds
everyonce in a while (becinung more frequently now) when i shift from 1st to 2nd, theres a low grinding sound......not like a mis shift/bad clutch work, this is very low sounding, and his happening even when the clutch is all the way in.....i was thinking mayb the syncro on the 2nd gear collar is going bad and making improper contact???...i realy dont know all that much about trannies...anybody got a clue???
Old Feb 1, 2004 | 01:02 PM
Duster's Avatar
Default Re: Shift grinds (fw190bvi)
syncros prolly going, i had the exact same thing and i got new syncros put in and nows its fine
Old Feb 1, 2004 | 04:39 PM
GreenBean's Avatar
Default Re: Shift grinds (Mazdillac)
If its within warranty (your sig might not be your ride) have a technician at the delaer drive it and tell you....If so the warranty will replace hat they need to so you can shift smoothly.
Old Feb 1, 2004 | 07:01 PM
snatch13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mazdillac &raquo;</TD></TR><TR><TD CLASS="quote">syncros prolly going, i had the exact same thing and i got new syncros put in and nows its fine</TD></TR></TABLE>
i heard thats pretty expensive?? how much for new synchros? my third gear synchro is all fucked up so im gonna need to do that soon... if its too much im prob just gonna go h22
Old Feb 2, 2004 | 11:12 AM
fw190bvi's Avatar
Default Re: Shift grinds (snatch13)
well......after a more careful analyzation, its might be from teh cold....only seems to be happening when the shifter feels stiff (from the cold in teh morning).....im not gonna worry about it for now, but thanks for the heads up.....if it is the syncro, i bet its from all my 4-&gt;2 heel-toes at 40mph.....oh well thanks yall
Old Feb 2, 2004 | 12:13 PM
jweller's Avatar
try changing the tranny fluid. if the fluid has some mileage or time on it, new fluid can improve shift quality
Old Feb 2, 2004 | 07:36 PM
LookingForVTEC's Avatar
who did you work and how much did it cost??
Old Feb 3, 2004 | 03:22 AM
KGAccord's Avatar
Default Re: Shift grinds (LookingForVTEC)
what tranny fluid are your using?? i would first try honda mtl, if that doesn't work try redline mtl, and then try gm synchromesh.
Old Feb 3, 2004 | 09:41 AM
djric23's Avatar
if u want to check first drain the tranny fluid and if u see gold metal particles its your syncros Im pretty sure its the syncros
Old Feb 3, 2004 | 12:29 PM
fw190bvi's Avatar
Default Re: Shift grinds (djric23)
thanks agian yall.....im just pretty sure its the cold, but who knows.......ill check the tranny fluid when i change my oil......hmm......i could use an oil change soon too.......
Old Feb 3, 2004 | 01:38 PM
xamraci's Avatar
I was experiencing the same thing while the temperature has been low...just shift slow and easy until the car has warmed up a bit...that is what I have been doing...and my OIL change IS tomorrow...so tranny fluid and check-up is coming also
AwOrKiNpRoGrEsS23
Aug 29, 2006 11:19 AM
EG type GTR
Jul 26, 2006 07:20 AM
Vouthanack
May 6, 2004 06:47 PM
SKDRCR
Aug 21, 2003 07:50 AM
weakGOODJunKieS.com
May 8, 2003 06:14 AM
