what causes rod knock?
Old May 6, 2004 | 06:07 AM
hatchback_al's Avatar
Default what causes rod knock?
hey guys, i have a y8 swap in my car that i did a few months ago. it was a great motor and still is, it burns no oil or coolant and runs very strong. recently though it has developed a knocking rod so im going to swap out the block. this motor has only 63K miles on it, what the hell would cause the rod to knock so soon. I changed the oil every 3 and didn't beat on it all that hard. What would cause it to happen?
Old May 6, 2004 | 10:44 AM
Default Re: what causes rod knock? (hatchback_al)
bump
Old May 6, 2004 | 12:13 PM
doublejz's Avatar
could have spun a bearing, change your oil and see if theres any copper shavings in it
Old May 6, 2004 | 12:24 PM
hondatechnician's Avatar
could be a out of balance crankshaft or to much bearing clearance
Old May 6, 2004 | 08:20 PM
Default Re: what causes rod knock? (hondatechnician)
i DID once have my crankpulley come off. i was driving rather enthusiastically down the highway then pulled off to get some gas, when i started it to leave my alternator belt was squeaking like crazy. i get out as its running and i notice the belt is no running straight back, its running diagonally. i shut the car off to investigate and the crank pulley was really loose!! the woodruff key fell out, i replaced it on the spot and got it all good. think i damaged the crank?
Old May 6, 2004 | 09:31 PM
boostn420's Avatar
Its possible that the pulley coming off caused the thrust bearings to fall out of position. Try to move the crank in and out.
teg gs
Sep 19, 2018 02:21 PM
Thepowderblue
Jul 28, 2012 12:09 PM
cmamtower
Mar 10, 2010 07:10 PM
sipolt89
15
Dec 29, 2008 03:04 PM
