Tranny or clutch Failure?
Old May 6, 2004 | 04:28 AM
monEmakindave's Avatar
Default Tranny or clutch Failure?
after running my all motor car this weekend pulling 1.8 and 1.7 60's all day after the 10th run car doesn't want to go into gear, will slide into third only when the car is running. if i turn the car off it will go into every gear with clutch depressed. but if car is running i have to rev car to 3-4000 rpm and it slides into gear. There s a clutch masters stage 4 clutch and lightened flywheel. I have had friends with supras where the flywheel bolts come loose through time. Could this be a problem? Has anyone else had this problem occur. Please chime in.....is the tranny done or clutch......since it engages when car is off i m leaning towards the clutch. will drop the tranny in a few days just need some opinions.
Old May 6, 2004 | 04:44 AM
Kal's Avatar
Kal
Default Re: Tranny or clutch Failure? (dabullet)
i think it's the clutch.
Old May 6, 2004 | 11:06 AM
jdmint3gra's Avatar
Default Re: Tranny or clutch Failure? (Kal)
yeah i do too think it the clutch
Old May 6, 2004 | 11:38 AM
egsleepercivic's Avatar
It may be your slave cylinder or clutch master cylinder, if the clutch was shot it would still go in to gear you just would go any where
Old May 6, 2004 | 12:10 PM
doublejz's Avatar
Default Re: Tranny or clutch Failure? (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">It may be your slave cylinder or clutch master cylinder, if the clutch was shot it would still go in to gear you just would go any where </TD></TR></TABLE>
thats what i would check first, at the end of the day the plungers (in the master or slave) may not want to work anymore
if not, then clutch
GreatShamanGT
Transmission & Drivetrain
Feb 17, 2014 08:14 AM
spyderpaint88
Mar 15, 2008 04:38 PM
Z7
11
Feb 9, 2006 06:53 PM
litterbox
11
Sep 2, 2005 04:40 AM
H23vtecEG
Aug 15, 2005 01:30 PM
