Need Lots of Help with Turboing my R!
Old Nov 4, 2001 | 12:39 PM
AllMotorITR's Avatar
New User
Default Need Lots of Help with Turboing my R!
Ok, so I have finally decided to turbo my R... Most likely I am going to go with a Drag III Turbo kit, unless there are better ones. In order to run as safe as possible (engine wise), what other mods and parts am I going to have to do/buy? Pistons? FPR? etc.... Any help would be great. Also, what is the average boost people are running on their Rs? My goal is anywhere in the 12s... (preferably on street tires.)
Thanks for all the help in advance.
Chris
Old Nov 4, 2001 | 01:14 PM
LsTurbo91's Avatar
Default Re: Need Lots of Help with Turboing my R! (1 FAST R)
Standalone=Tuning=Safe
Old Nov 4, 2001 | 01:15 PM
New User
Default Re: Need Lots of Help with Turboing my R! (LsTurbo91)
See.. What is standalone? What are you referring to?
Old Nov 4, 2001 | 01:17 PM
LsTurbo91's Avatar
standalone is a computer that replaces/modify your stock ECU to read boost, you will have full control of timing and fuel.
Old Nov 4, 2001 | 01:18 PM
New User
won't I need to lower my compression and such? How many pounds of boost will I need to run, in order to hit 12s on street tires?
Old Nov 4, 2001 | 01:22 PM
LsTurbo91's Avatar
If you wanna boost high then lower your compression its all on you, 12's on street tires?
Old Nov 4, 2001 | 01:28 PM
jinxproof99's Avatar
New User
you'll need more than boost to run 12's in a type r on street tires. i'd say 300 hsp to the wheels at least, drag radials, a raped clutch/tranny with lsd, and some type of traction control. avcr, profec b, etc.....then learn how to drive it.
Old Nov 4, 2001 | 01:29 PM
New User
How much boost are you running, and what 1/4 times? Maybe not 12s on street tires hehe... More like low to mid 13s...
Old Nov 4, 2001 | 01:36 PM
New User
don't get me wrong. 12's in a type r w/ st tires is totally possible. its just you'll need most of the things i'm talking about.
i run mid 11's on slicks when my cars running good. 11.70's to 12.0 when its not.
12.60's-12.80's on street tires.
also....its not about the boost....its about the horsepower and torque. you'll need 300+ hsp and that means lowered compression or EXTREMELY fine tuning(which usually leads to premature faiure for the average person)
[Modified by jinxproof99, 5:38 PM 11/4/2001]
Old Nov 4, 2001 | 01:39 PM
TurboIntegra's Avatar
I have a turbo R. I took it to the track and ran high 12's low 13's easy on STREET TIRES.
I have a stock internals and a differnt headgasket to lower my compression. I made 320hp with a drag gen III and standalone (hondata).
Old Nov 4, 2001 | 02:07 PM
New User
Default Re: Need Lots of Help with Turboing my R! (TurboIntegra)
nice
Old Nov 4, 2001 | 04:26 PM
lazyvietboi's Avatar
which stage hondata u get?
antballs420
Aug 21, 2005 09:51 AM
sonek
May 19, 2005 08:35 AM
sunny79
Oct 20, 2002 02:58 PM
X2BOARD
Apr 18, 2002 10:51 AM
