Wont boost over 4 PSI on greddy Sohc Kit
Old May 5, 2004 | 05:30 PM
GorData's Avatar
Default Wont boost over 4 PSI on greddy Sohc Kit
I just installed a greddy Sohc Turbo Kit into My delsol with a jdm D15B, The turbo spools and BOV sounds but cant get past 4 PSI. I tried to put a Vacuum tee in between the Nipple of the compressor and the wastegate one to raise boost but still nothing. I need some help, I have the BOV to Manifold.
Old May 5, 2004 | 07:22 PM
integrx's Avatar
New User
Default Re: Wont boost over 4 PSI on greddy Sohc Kit (vteccivicsi92)
do you have a mbc? check for leaks, and run vacuum from intake manifold source. be sure to cap off the compressor side.
Old May 5, 2004 | 07:59 PM
Pengo's Avatar
check for leaks in your charge piping. make sure none of them popped loose. it happens pretty often, esp if if it's your first time installing and you were eager to finish and didnt tighten down a clamp on a silicone sleeve quite tite enuff. check every single connection.
if its not that, you could try plugging off the compressor nipple and using the intake mani for the vac source for the wg. you have the bov set up right but it wouldnt mean much if your already leaking off boost at the wg. and of course make sure the arm on the wg isn't hitting anything or staying slightly open all the time. good luck
Old May 5, 2004 | 08:49 PM
GorData's Avatar
Default Re: Wont boost over 4 PSI on greddy Sohc Kit (Pengo)
Going to Cap off the compressor Nipple and run it from the Manifold, Will let You guy know tomorrow what happened.
Old May 9, 2004 | 05:32 AM
RICE POLICE SIP's Avatar
Is it brand new or used? Did anyone mess with the wastegate actuator? Cause' you can change the boost from that... Good luck though...
Old May 13, 2004 | 01:30 AM
integrx's Avatar
New User
any results?
Old May 13, 2004 | 02:15 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Wont boost over 4 PSI on greddy Sohc Kit (integrx)
sounds like pressure drop cause of the intercooler . stock boost is 5.5 without intercooler .
see if you have your wastegate actuator hooked up how its supposed to , to the compressor , the compressor will see 5.5 but thats not what the car is seeing , so hook it to the IM , then youll be good to go
Old May 13, 2004 | 06:45 AM
FuriousGeorge's Avatar
Default Re: Wont boost over 4 PSI on greddy Sohc Kit (Hella_JDM)
Check for leaks. I had to get under my car 2-3 times after I put my kit on b/c I didnt tighten couplers enough. After that hook your WG up to IM source. If that doesnt work, take the WG off the turbo and adjust the boost. I've adjusted mine up to 8 by this method.
http://www.gamesbbs.com/~dmoore/turbo-tuning.htm
95civ
Sep 5, 2005 03:17 PM
VTC_CiViC
Dec 14, 2004 07:13 AM
95gsrturbo
Mar 17, 2004 11:51 PM
TerdFerguson
Sep 15, 2002 06:43 PM
BigD+Itsuki
Aug 5, 2002 10:45 AM
