I have searched------bogging when weather is hot........?
i have a 97 GSR when the weather is warm or hot outside my car has a really bad bog....You can floor the car and it feels bogged out all the way up RPMs it bogs so hard sometimes you almost lean forward in the seat....Only mod i have is CAI....Any suggestions????? 83,000 miles....
I went through that problem before last week at the local drag strip. It was in the high 50's with 89% humidity...... I think the humidity has something to do with the performance. My teg runs good in the cold too. Anyone think a radiator upgrade helps this?
a radiator upgrade will help the car engine run cooler....If the weather is hot my car falls on its face with bog i literally lean foward in the seat sometime cause it bogs and if you floor it when it does this it feels like its reving but not hardly pulling only in the heat it didnt do it before it did it a few times and gradually got worse over about a year....any help??????
FOrSfEd
Feb 5, 2004 04:48 PM
