bent rod/resleeve
Old May 5, 2004 | 02:44 PM
prelewd's Avatar
Default bent rod/resleeve
What kind of block damage results from a bent rod? Would a scared cylinder wall result from this? I'm not sure why the rod is bent in the first place, but give me a worst case scenario..
I'm trying to pick up an h23 block for cheap to send out for a resleeve, but I don't want to spend my money on something that isn't going to even work right in the long run.
All help is appreciated, thanks.
Old May 5, 2004 | 02:53 PM
RyanEJ8's Avatar
Default Re: bent rod/resleeve (prelewd)
It could have damaged it. The only way to find out is to pull the block. How do you know you have a bent rod anyways?
Old May 5, 2004 | 10:27 PM
LudeyKrus's Avatar
Unless the rod snapped, the block should be fine. I've bent rods in an H23 twice, and the cylinders were fine both times.
Old May 6, 2004 | 06:43 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
First, Ryan is correct, the only way to know for sure is to tear it down and check everything.
Second, if it bends in the direction of rotation and doesn't bend too far it shouldn't cause any major damage. If it bends in the direction of the crank axis then it will likely cause some cylinder damage because the wrist pin will force the bottom of the piston against, say, the back (#4) side of the cylinder and the top of the piston against the front (#1) side of the cylinder. Only one way to find out...
TheCivicMafia
Apr 30, 2009 01:08 AM
RyanA
Jul 17, 2007 04:14 PM
AndyD
Nov 22, 2002 03:26 PM
B pwr
Oct 30, 2002 11:45 AM
