brake light came on the dash board
Old May 5, 2004 | 01:39 PM
wilntegra's Avatar
Default brake light came on the dash board
the problems on a 91 integra brakes pads are ok in front and back, fluid level ok and not long ago installed a new master cylinder.. whoever knows let me know.....
Old May 5, 2004 | 01:49 PM
frenchy's Avatar
Default Re: brake light came on the dash board (wilntegra)
does it say brake or abs - brake is ebrake abs is brake probs
Old May 5, 2004 | 01:51 PM
wilntegra's Avatar
Default Re: brake light came on the dash board (frenchy)
ebrake is down and i dont have abs
Old May 5, 2004 | 01:52 PM
shamoo's Avatar
Will you make something up for me please?
Check your brake fluid level.....again.
Old May 5, 2004 | 01:57 PM
frenchy's Avatar
Default Re: brake light came on the dash board (shamoo)
as far as i know the light on the gauge is only for the ebrake - anyone know better?
Old May 5, 2004 | 04:39 PM
gsrboi80's Avatar
this happened to my 2000 gsr it's under warranty so i brought it to acura. They said it was the break light switch under the dash. has not come back since
Old May 5, 2004 | 04:58 PM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frenchy &raquo;</TD></TR><TR><TD CLASS="quote">as far as i know the light on the gauge is only for the ebrake - anyone know better?</TD></TR></TABLE>
that would be correct.
Old May 5, 2004 | 05:42 PM
'94gsR's Avatar
New User
ive had it come on before because of low break fluid level. thats all i know it would be from.
Old May 5, 2004 | 05:55 PM
hadehatch's Avatar
Default Re: brake light came on the dash board (svtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">
that would be correct.</TD></TR></TABLE>
not exactly it also comes on if the brake fluid level is low as others have stated.. check the fluid..
if everything is ok then maybe you didnt connect those wires on the cap of the master cylinder and now they are touching..
Old May 5, 2004 | 08:39 PM
svtec's Avatar
L D E S
Default Re: brake light came on the dash board (hadehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadehatch &raquo;</TD></TR><TR><TD CLASS="quote">not exactly it also comes on if the brake fluid level is low as others have stated.. check the fluid..
if everything is ok then maybe you didnt connect those wires on the cap of the master cylinder and now they are touching.. </TD></TR></TABLE>
it must have to be lower than hell then. i have never had that light come on in any of my hondas except for when the e-brake was on. if i get a chance i will look in my helms because i'm not feelin that.
Old May 5, 2004 | 09:42 PM
shamoo's Avatar
it must have to be lower than hell then. i have never had that light come on in any of my hondas except for when the e-brake was on. if i get a chance i will look in my helms because i'm not feelin that.</TD></TR></TABLE>
Yeah, it's true. E-brake light is the indicator for low brake fluid AND the E-brake being engaged. It doesn't have to be that low for it to come on.
Old May 6, 2004 | 09:49 AM
frenchy's Avatar
well then i would say the concensus is that if the fliud is at the right level than its a wiring/switch issue, and not a brake problem
Old May 6, 2004 | 04:46 PM
wilntegra's Avatar
well the fluid is full im going to buy that switch tommorow to see if its that ....ill let u know what happens thanks....good looking out....
Old May 6, 2004 | 06:26 PM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilntegra &raquo;</TD></TR><TR><TD CLASS="quote">well the fluid is full im going to buy that switch tommorow to see if its that ....ill let u know what happens thanks....good looking out.... </TD></TR></TABLE>
you better make sure the fluid level is full because apparently it doesn't have to be that low to trigger the sensor.
Old May 7, 2004 | 03:44 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilntegra &raquo;</TD></TR><TR><TD CLASS="quote">well the fluid is full im going to buy that switch tommorow to see if its that ....ill let u know what happens thanks....good looking out.... </TD></TR></TABLE>The fluid level switch closes the circuit to turn on the light. So unplug the wires at the fluid reservoir. If the light still comes on, then look elsewhere for the problem.
Same thing for the handbrake switch. It closes the circuit to light the light. That thing can get bent or something, so even when the lever is down, the switch is still closed. It might be as simple as bending the bracket back where it belongs.
Old May 7, 2004 | 08:48 AM
tqhill3's Avatar
are your calipers leaking?
Old May 7, 2004 | 08:56 AM
Devlins 91LS's Avatar
Default Re: (tqhill3)
I had the same problem after i changed out my brake bads and had to bleed the brake lines. Fill it up a little over the "high level" or wtfever it says, and you'll be good to go
misterix
Nov 22, 2010 03:19 AM
supermotothud
Nov 10, 2008 04:09 PM
nochel
May 26, 2008 08:06 PM
mikester_91
Jan 18, 2005 01:14 PM
autosell2001
Aug 26, 2003 04:22 PM
