No spark...technicians I need your help
Old May 5, 2004 | 01:13 PM
almighty's Avatar
Default No spark...technicians I need your help
I can't seem to figure out how to solve this problem. I'm getting no spark. The engine turns over, all the gauge lights come on, but it won't catch. I pulled one of the spark plug wires stuck a socket extension in it and grounded it to the body...NO SPARK! I've tried replacing the ignitor, and the coil (both twice with two different NIB parts). Used a volt-meter and the distributor is getting the proper voltage. Also checked all fuses as well as the main reply. Everything looks a-ok. I also tired a different stock ECU and new spark plug wires. If it matters, when the engine turns over, the tach needle does not bounce at all. The car drove fine before, I parked it and in the morning it wouldn't start. Any help would be greatly appreciated...
Oh, the car is a bone-stock 1992 Honda Civic Si.
Thanks.
Old May 5, 2004 | 04:16 PM
Runnerdown's Avatar
Default Re: No spark...technicians I need your help (almighty "H")
Swap over a known good distributor - the whole thing not just parts.
Old May 5, 2004 | 04:53 PM
92slowvic's Avatar
i had a similar porblem not sure if your in the same situation but check the ground on the harness thats runs to the side of the distributer........good luck
smoovekriminal
Aug 17, 2007 09:55 PM
intgraCA
Jul 27, 2006 09:12 AM
inzaneN1
Jul 12, 2003 03:16 PM
reese
Sep 2, 2002 11:59 PM
Ri5e
Apr 4, 2002 12:20 PM
