do these sparkplugs look like there in normal condition...> ?
Well i am running 850cc injectors with Hondata but at idle my car starts to lean out and then rich-ins it self out for a while and then starts to lean out again... > ? could this be my part throtle tunning i have the techedge wide band hooked up to the ecus 02 linear signal and it still runs lean.. on the plugs there is little bulid up but dont know what that is looks like oil? and looks of the plugs the car is runing rich..
did a compression test 203- 205- 191 -198 compression JE 9:5:1
comp #s are fine, looks like your fowling plugs, sounds like a Cold idle enrichment problem. Or your running too cold plugs. Ether way those are pritty fowled
