question bout h23 to h22
Old May 4, 2004 | 05:44 PM
Mixdmixd's Avatar
Default question bout h23 to h22
ok i spun a bearing in my 93 si lude h23a1 i found a h22a that i am buying soon and i am wondering what i need as far as like new ecu etc... plz help guys the car and engine sitting at uncles shop
Old May 4, 2004 | 06:08 PM
Hit N' Low lude's Avatar
Default Re: question bout h23 to h22 (Mixdmixd)
The easiest way to do the swap is getting the engine, trans, and ecu together.
Old May 4, 2004 | 06:30 PM
ensracer's Avatar
so you are going to buy an h22a engine, block and head right? everything will bolt up perfect. all you need is to get a vtec ecu obd1, you can get them or ebay for less than 200, just run the vtec wires and thats it. just a couple wires and an ecu. i did this before when i had a prelude but im not sure if the downpipe alingned with the vtec manifold but im pretty sure that is did not.
Old May 6, 2004 | 03:20 PM
Mixdmixd's Avatar
yeah the WHOLE thing is coming out not just block and **** the WHOLE thing so all i need to do is get some1 to run the vtec wires and ecu with obd1? right? thx for the help guys
Old May 6, 2004 | 04:07 PM
missdusty's Avatar
yah all you need to do is wire vtec. I did the same thing on my car and I switched from a p14 to a p13 ecu, which you need to do so that you can have vtec.
nothing_shocking
Feb 17, 2009 12:16 PM
rmiller
Feb 1, 2008 10:10 PM
skylude23
Jan 18, 2007 06:54 AM
J_Lude07
Apr 1, 2005 09:48 AM
