Hondata S200/ CEL on dash w/ no codes in hondalogger???
Old May 4, 2004 | 04:52 PM
BOOST_MAN's Avatar
Default Hondata S200/ CEL on dash w/ no codes in hondalogger???
00' Integra LS p28 w/ obd2 connector / S200
Dash check engine light is on but hondalogger shows no codes, I even tried to clear codes and the cel light did not go off. Everything else works fine, just has that cel? Anyone got any ideas? I just want to make sure that this is not an indicator of some other problem.
Old May 4, 2004 | 04:57 PM
ladysman's Avatar
Default Re: Hondata S200/ CEL on dash w/ no codes in hondalogger??? (BOOST_MAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOST_MAN &raquo;</TD></TR><TR><TD CLASS="quote">00' Integra LS p28 w/ obd2 connector / S200
Dash check engine light is on but hondalogger shows no codes, I even tried to clear codes and the cel light did not go off. Everything else works fine, just has that cel? Anyone got any ideas? I just want to make sure that this is not an indicator of some other problem.</TD></TR></TABLE>
Is the light on solid or blinking?
Old May 4, 2004 | 04:58 PM
BOOST_MAN's Avatar
Default Re: Hondata S200/ CEL on dash w/ no codes in hondalogger??? (ladysman)
it is solid, it just stays on
Old May 4, 2004 | 05:15 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOST_MAN &raquo;</TD></TR><TR><TD CLASS="quote">it is solid, it just stays on</TD></TR></TABLE>
This means the rom wasn't loaded or the ECU doesn't see a rom loaded.
Are you using a chip?
Are you using the Romulator?
Are you using the Programmer with the emulator?
Did you take the chip out of the box and put it in the ECu and notice the light was on?
Old May 4, 2004 | 05:17 PM
BOOST_MAN's Avatar
I am emulating with 520cc injectors. The car runs just fine and it recognizes my realtime changes.
Old May 4, 2004 | 05:26 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOST_MAN &raquo;</TD></TR><TR><TD CLASS="quote">I am emulating with 520cc injectors. The car runs just fine and it recognizes my realtime changes.</TD></TR></TABLE>
Did you load the rom then turn the key off and cycle it back on?
Old May 4, 2004 | 05:30 PM
BOOST_MAN's Avatar
yes, this is the second time that this has happened, it is after i have been driving and i notice that the cel is on. The S200 red led is on and solid, the datalogging never kicks off or anything. other than the cel being on it seems as if there is nothing wrong
Old May 4, 2004 | 05:41 PM
BOOST_MAN's Avatar
hey man, I just read an archived section from the hondata fourm about this, I am going to go check it out here is the post:
http://hondata.com/forum/viewt...t=cel
Old May 4, 2004 | 06:05 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOST_MAN &raquo;</TD></TR><TR><TD CLASS="quote">hey man, I just read an archived section from the hondata fourm about this, I am going to go check it out here is the post:
http://hondata.com/forum/viewt...t=cel</TD></TR></TABLE>
My next thought was a revlimit but if it is off then just comes on after a while, I am not sure that is the problem
94ls
Oct 20, 2005 03:55 PM
EnzoSpeed
Oct 18, 2005 11:21 PM
stealth89hatch
Aug 15, 2005 04:48 PM
1115R
Sep 11, 2004 08:33 PM
BOOST_MAN
May 5, 2004 08:26 AM
