Changing a Header
Old May 4, 2004 | 04:26 PM
BeBe's Avatar
Default Changing a Header
What is there to know about changing your header? How difficult is it? How long does it take and what mistakes are commonly made? What are the steps to do this...
Old May 4, 2004 | 05:36 PM
insomniac791's Avatar
it is very easy. Let the car cool down but not until it is cold let it be a little warm the bolts come out easier when a little warm. Spray them with pb blaster and let them sit for a few minutes. Take the bolts of where the header bolts to the block. The most common one that breaks off is the farthest passenger side lower bolt. After you get those off take the two bolts off where the catalaytic converter meets the header spary it with plenty of PB Blaster. There may be a few misc bolt that holds the stock manifold on but I did not reuse them when I put my new header on. Reuse your stock exhaust donut and gasket. Put your bolts back the block and torque them down to 22 lbs of torque.
should be it.
later
Matt
Old May 4, 2004 | 05:40 PM
BeBe's Avatar
Default Re: (insomniac791)
Just to clarify, how do you know if it's 22 ft lbs of torque with the socket?
Old May 4, 2004 | 05:43 PM
zad5's Avatar
buy a torque wrench and set it to 22ft.
Old May 4, 2004 | 08:39 PM
BeBe's Avatar
Default Re: (zad5)
OK
bsampson
Jan 24, 2009 11:58 PM
Maireeka
May 17, 2006 07:33 PM
dohc-nyne
Sep 11, 2003 03:21 PM
Vampyre
Feb 12, 2002 03:38 PM
MintyDip
Aug 2, 2001 06:52 PM
