Just mesured my main bearing clerances, one is tight???
Old May 4, 2004 | 01:24 PM
leadfoot78's Avatar
Default Just mesured my main bearing clerances, one is tight???
Ok all my clerances came out good except bearing # 4 is showing .0010 clerance, acording to Helms manual its within spec but its border line cuz the clerance should be .009 - .0017. Should I replace that bearing or will the tight clreance be ok?? I don't want spun bearings, I did everything right, I ordered the right Honda bearings and did every thing by the book.
Old May 4, 2004 | 01:40 PM
RyanEJ8's Avatar
Default Re: Just mesured my main bearing clerances, one is tight??? (leadfoot78)
It MIGHT be okay. You have to keep in mind the Honda tolerances are for a "normally" driven vehicle. If you plan on revving much higher than factory redline, you may want resize that bearing.
Old May 4, 2004 | 01:54 PM
turbosi03's Avatar
good question, I should be starting my build in a few weeks when the block gets back from the shop... can't wait to see the answer.
I would also like to know if the tolerances change for a high hp build?
If so, how can we find out what tol is right for our setup?
Old May 4, 2004 | 02:06 PM
leadfoot78's Avatar
Default Re: Just mesured my main bearing clerances, one is tight??? (turbosi03)
It's going to be a turbo 2.0L, so the numbers will be pretty high hopefully. I'm going to plastiguage them again and see what happens.
Old May 4, 2004 | 02:27 PM
IN VTEC's Avatar
What color bearing are you using on the #4 main? Maybe you should go down a color or two.
Old May 4, 2004 | 03:04 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Also make sure that there isn't even the tiniest spec of grit or anything between the bearing shell and the cap/block. You might also want to have someone mic that crank journal and bearing cap to find out which one is off.
Old May 4, 2004 | 03:05 PM
Br1t1shguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leadfoot78 &raquo;</TD></TR><TR><TD CLASS="quote">Ok all my clerances came out good except bearing # 4 is showing .0010 clerance, acording to Helms manual its within spec but its border line cuz the clerance should be .009 - .0017. Should I replace that bearing or will the tight clreance be ok?? I don't want spun bearings, I did everything right, I ordered the right Honda bearings and did every thing by the book. </TD></TR></TABLE>
If its in spec its fine. Honda is smart, honda has awesome clearences comparative to other manufacturers.
Old May 4, 2004 | 10:16 PM
leadfoot78's Avatar
Default Re: Just mesured my main bearing clerances, one is tight??? (Br1t1shguy)
Ok, I remeasured it(cleaned the #4 cap aggressively) and it all came out good. But now I noticed that my #2 upper main bearing has a speck of dirt embedded in it so I had to order a new one and I will pick it up tomorrow. Also, my first attempt at gaping my rings failed, I gaped it to .035 and made the ring useless have to order another one.
Old May 4, 2004 | 10:24 PM
Flamenco-T's Avatar
one thing that you can try if you get a little too tight or too lose is this,
Try to change one bearing color, Just one bearing. For example, if your bearing code calls for black and it's a little too tight, try to take either the top or lower bearing and use the brown one instead, so instead of black/black, now you have black/brown, a little looser.
I run split bearings on my motor and I get .0015 on ALL cylinders.
just a thought,
Stan
Old May 4, 2004 | 10:42 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Just mesured my main bearing clerances, one is tight??? (Flamenco-T)
I shoot for .0015" them too.
Old May 5, 2004 | 10:46 AM
leadfoot78's Avatar
Default Re: Just mesured my main bearing clerances, one is tight??? (Arturbo)
Yeah, all of mine are around .0015 except #3 is around .002, but the helms calls for a looser clerance on that one anyway so im happy with that. Thanx for the help everyone!!
Old May 9, 2004 | 09:51 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I shoot for .0015" them too. </TD></TR></TABLE>
Flamenco-T's Avatar
I shoot for .0015" too from standing still
hahahahhaha
NoWorry's
May 6, 2013 06:12 PM
danthemang3
Aug 12, 2007 12:27 PM
yaoming315
Jul 21, 2007 11:46 PM
THEUSED
Mar 21, 2005 11:06 AM
jdmhatch94
Sep 13, 2003 02:03 PM
