Manual Transmission Disassembly
Old May 4, 2004 | 09:50 AM
exx's Avatar
exx
Default Manual Transmission Disassembly
Hey Guys,
First off my car's a 91 Civic Si HB 5spd. D16A6 engine.
The transmission in my car is making a lot of noise from what I believe is the input shaft bearing (Showing typical symptoms: Whirring noise especially noticeable in 1st-3rd, can hear it while car is in neutral with the clutch engaged. With the pedal pressed in (clutch disengaged) the noise immediately goes away.) So I know it's definitely not the throw bearing.
Now, I have a spare transmission (Also for a D16A6) in my garage which also has an input shaft issue. However, I've never had it in my car before so I'm not sure whether it has the same symptoms, but I wouldn't mind cracking it open and finding out for myself and perhaps even attempting to replace the bearing myself.
With that said, yesterday I tried to crack it open (without a manual.. ) and I got it split open about an inch, but cannot get it disassembled beyond that. Is there something I'm completely overlooking that needs to be unbolted to allow me to completely open it up?
Any help is greatly appreciated
Thanks!
Matt
Old May 4, 2004 | 09:54 AM
mmuller's Avatar
Mad Scientist
Default Re: Manual Transmission Disassembly (exx)
https://honda-tech.com/zerothread?id=644885
http://www.performanceforum.co....html
they are for b-series, but.....then again you dont have a service manual so..
you prolly forgot about the snap ring
Old May 4, 2004 | 10:10 AM
exx's Avatar
exx
Default Re: Manual Transmission Disassembly (mmuller)
Ahhh that's exactly what I needed
Thanks!
kyle0209
Honda Civic (2001 - 2005)
Oct 20, 2016 01:59 AM
Chucksinbong
13
May 19, 2013 01:08 AM
jdmfreak1992
Jul 26, 2011 04:52 PM
dls_tech
Dec 4, 2010 06:11 PM
exx
10
May 10, 2004 08:03 AM
