MINIME d16y7 d16y8: how do you get rid of CODE 91: Fuel tank pressure sensor??
Old May 4, 2004 | 07:50 AM
Civiclx's Avatar
Default MINIME d16y7 d16y8: how do you get rid of CODE 91: Fuel tank pressure sensor??
Does anyone know how to get rid of this code??
Old May 4, 2004 | 07:54 AM
TurboBumblBee's Avatar
Default Re: MINIME d16y7 d16y8: how do you get rid of CODE 91: Fuel tank pressure sensor?? (Civiclx)
try disconnecting the battery.. need more info on the swap and circumstances.. that codes is only for a 96+ obd2 cars i think...
Old May 4, 2004 | 10:26 AM
Civiclx's Avatar
Default Re: MINIME d16y7 d16y8: how do you get rid of CODE 91: Fuel tank pressure sensor?? (Boostfedb18c1)
its a d16y7 block, d16y8 head, d16y7 wiring harness
Old May 4, 2004 | 11:07 AM
monicle's Avatar
do you have your purge system hooked up and is your gas cap on?
Old May 4, 2004 | 11:19 AM
EG-cellent's Avatar
what car is this motor in and what ecu do you have?
Old May 4, 2004 | 11:31 AM
Civiclx's Avatar
Default Re: MINIME d16y7 d16y8: how do you get rid of CODE 91: Fuel tank pressure sensor?? (EG-cellent)
1997 dx
1997 ex ecu
minime
is the dx purge different than the ex?
Old May 4, 2004 | 11:38 AM
EG-cellent's Avatar
I am not sure if the purge are diff. but that code is for a 99+ car though. Are you sure you do not have a 99-00 ecu. b/c the 96-98 cars do not have that sensor.
Old May 4, 2004 | 12:04 PM
Civiclx's Avatar
yes 96-98 ex's have a 91 code
Old May 4, 2004 | 01:08 PM
monicle's Avatar
well youre getting it because youre ecu isnt seeing pressure in the fuel tank so either you have a leak somewhere stopping the pressure from building up, or youre fuel tank pressure sensor is bod/nothooked up/ (insert any other sensor trouble here).
Old May 4, 2004 | 04:29 PM
Civiclx's Avatar
Default Re: MINIME d16y7 d16y8: how do you get rid of CODE 91: Fuel tank pressure sensor?? (monicle)
dx fuel tanks dont have this sensor, this is a problem many people run into even when they swap dohc motors
Old May 5, 2004 | 10:46 PM
brooksto's Avatar
I have had this damn code ever since I did an auto to manual on my 96 ex. The helms has extensive troubleshooting to find out the problem, but you will need a multimeter and a vacuum pump to get started. I check all the lines, and tried replacing the canister so far, no luck. What year engine/head/harness are you using? Ive been wondering if the problem is a wiring issue that needs to be sorted out.
mwaedow
10
Nov 23, 2013 11:03 AM
mugenboi
May 24, 2007 11:49 AM
JDMJONES
Apr 14, 2004 03:38 PM
DR. ON POINT
Dec 27, 2002 02:32 PM
97hb
Mar 18, 2002 05:41 AM
