00 Si, parts compatibility (bumpers, lights, suspension)
I might be purchasing a nearly bare shell from a 2000 Si. It needs bumpers, lights and suspension among other things. I was just wondering what years bumpers, tail lights and headlights might fit: any year from 96-00, or must they be from a particular year? Also, can these parts come from a sedan or hatch, or only from a coupe?
Concerning the suspension and brakes, basically the same question: can I fit parts from other generations of Civics (knuckles, calipers, wishbones, etc.) or must I buy 96-00 stuff, or specifically Si stuff? I need the brakes to be at least as big as stock as this will be a rae car. Thanks.
I can't believe your asking this ?
You'll need 99-00 any civic headlamps, taillamps (coupe), front bumper (any). rear bumper (coupe), side skirts (coupe/hatch - painted to match)
99-00 si onlylip spoiler, front grill, f & r sway bar, front Lca's & front forks, shocks & springs (or use aftermkt)
(96-00EX or 99-00Si) hubs/spindles/ brakes front & rear....not sure if you still have the Si master cylinder, prop valve, ebrake lines, etc (i believe the brake booster is the same
other suspension pieces can be used from any 96-00 civic (i believe - feel free to correct me if I am wrong)
)other suspension pieces can be used from any 96-00 civic (i believe - feel free to correct me if I am wrong)
Thank you for the responses so far.
Shocks and springs will be koni-ground control
Swaybars will be aftermarket.
Is there any way to fit any part of my 90-93 integra brake system (10.2 inch)? Are the Si brakes bigger than the Integra brakes?
Does the grill from other coupes not fit? I don't care if it looks like an Si or not, I just want to make a complete-looking car.
Thanks.
Thanks.
brakes are the same rotor size 10.3" in the front so they should work but may not have the same fittings - check HERE ---> https://honda-tech.com/zerothread?id=152884 ---after searching I would say look for 96-00 ex brake swap
for easier installation
any 99-00 civic grill will work...you can have my dx one (painted tafetta white) in the next couple of weeks
I am getting the si grill painted to match my car
for easier installation any 99-00 civic grill will work...you can have my dx one (painted tafetta white) in the next couple of weeks
Snail Power
Jan 30, 2009 03:37 AM
Navid OG
Oct 14, 2003 10:14 AM
