B16 BEING BUILT FOR TURBO @ 10PSI TO START~~~~~~~~~~~~~~~~~~~~
Old May 4, 2004 | 05:50 AM
Freeltec's Avatar
Default B16 BEING BUILT FOR TURBO @ 10PSI TO START~~~~~~~~~~~~~~~~~~~~
HERES WHAT IM IN PROCESS OF BUILDING:
B16A1
GSR CAMS
TYPE R VALVE SPRINGS
ARP HEAD STUDS
STOCK VALVES
GOLDENEAGLE BLOCKGUARD
STOCK HEAD GASKET
9:1 ARIAS PISTONS STOCK BORE
EAGLE FORGED RODS
STOCK RINGS
WHAT CAN THIS MOTOR TAKE WITH GOOD TUNING? HORSEPOWER? BOOST?
what can i expect from this setup with a t3 .48 ar and 450 cc injectors
Old May 4, 2004 | 05:54 AM
Freeltec's Avatar
Default Re: B16 BEING BUILT FOR TURBO @ 10PSI TO START~~~~~~~~~~~~~~~~~~~~ (Freeltec)
OH YEAH,
i got 450 cc injectors vafc and fuel pump for management for now
goin in my 4g hatch
Old May 4, 2004 | 06:10 AM
m R g S r's Avatar
Why bother guessing? Dyno it and tell us.
Old May 4, 2004 | 01:31 PM
Freeltec's Avatar
Default Re: B16 BEING BUILT FOR TURBO @ 10PSI TO START~~~~~~~~~~~~~~~~~~~~ (m R g S r)
gee thanx.... i will dyno later but i want an estimate of how much power i should aproximiatly make with this setup anybody have a similar setup
Old May 4, 2004 | 03:13 PM
havok hybrid's Avatar
10 psi... with a average turbo... i see like 260-280 .. whp ... on pump gas
Old May 4, 2004 | 03:32 PM
TurboJesse
Guest
Posts: n/a
Default Re: B16 BEING BUILT FOR TURBO @ 10PSI TO START~~~~~~~~~~~~~~~~~~~~ (havok hybrid)
i say maybe 240 with that turbo, i doubt it though
Old May 4, 2004 | 03:51 PM
Jonny Black's Avatar
Default Re: B16 BEING BUILT FOR TURBO @ 10PSI TO START~~~~~~~~~~~~~~~~~~~~ (Mpir3)
at 10 psi and a bone stock B16a I am making over 250 to the wheels now. so there you go.
Old May 4, 2004 | 04:27 PM
Freeltec's Avatar
what would i need to ugrade my setup to be able to make 350whp?injectors?hondata s200??
is 350 possible with the internals and gsr cams and blockguard
Old May 4, 2004 | 04:30 PM
TurboJesse
Guest
Posts: n/a
i made over 250 on 6.5psi...its all in the setup, you would need a larger turbo and bigger injectors/hondata/uberdata..
mrx
Feb 15, 2021 03:33 AM
lilbinky
May 20, 2013 06:42 AM
Sleeperzzz95
Mar 12, 2010 08:29 PM
Samuels
Aug 11, 2006 06:39 PM
SpeedingHatch
Jun 5, 2006 12:43 PM
