Need Quick Question About Turbo Help
Old May 4, 2004 | 05:39 AM
H.crx-si
Guest
Posts: n/a
Default Need Quick Question About Turbo Help
Hey I'm doing a junkyard setup on my crx d16a6. Does it matter if I use a turbo from a 1st gen or 2nd gen eclipse that came from an automatic or is it any different then the one that came on the manual 5speed models????
Old May 4, 2004 | 05:49 AM
H.crx-si
Guest
Posts: n/a
Default Re: Need Quick Question About Turbo Help (H.crx-si)
I need to know if this will fit my car and what kind of turbo it is.
Old May 4, 2004 | 05:58 AM
ScrapinSi's Avatar
need closer pics of it to tell you what kind of turbo it is... it is TINY i can tell you that.
Old May 4, 2004 | 06:08 AM
H.crx-si
Guest
Posts: n/a
If I can get it for $115 cnd funds think its worth it? guy says it spins great and fins are excellent.
Old May 4, 2004 | 06:54 AM
lohatch's Avatar
it looks to be from a 1g dsm. if it is from a auto car it is a 13b rather than a 14b. it is just a touch smaller but nothing really noticable. yes that will work on your crx. are you going to be running a HF manifold? if so you are going to be need an adapter to bolt everything up. that turbo will spool pretty quick and should pull til redline. check out http://www.homemadeturbo.com for more info
Old May 4, 2004 | 07:00 AM
Rod.'s Avatar
Default Re: Need Quick Question About Turbo Help (lohatch)
1st gen eclipse comes with a td05
2nd gen come with a t25.
Get the one off the 1st gen
Old May 4, 2004 | 07:12 AM
H.crx-si
Guest
Posts: n/a
I've checked out homemadeturbo before and I'm pretty well educated in how a turbo kit works and what I need I was just not 100% sure which turbo this was because the guy thats selling it dosnt know either. He just knows its a eclipse turbo. Thanks for the replies though I bought it and I'm gonna try and run a dsm smic, dsm bov, hf header and I'm undecided on my charge pipes so far. I'm shooting for 5-6psi I just need a little more power and I'm on a budget.
JdMJ0hnny
Nov 22, 2009 08:23 PM
The Weather Man
Jul 27, 2005 09:44 PM
djsire
May 15, 2005 10:12 AM
H.crx-si
10
Apr 18, 2004 10:56 AM
del_sol
Oct 31, 2002 09:50 AM
