Need Quick Question About Turbo Help
Guest
Posts: n/a
Hey I'm doing a junkyard setup on my crx d16a6. Does it matter if I use a turbo from a 1st gen or 2nd gen eclipse that came from an automatic or is it any different then the one that came on the manual 5speed models????
it looks to be from a 1g dsm. if it is from a auto car it is a 13b rather than a 14b. it is just a touch smaller but nothing really noticable. yes that will work on your crx. are you going to be running a HF manifold? if so you are going to be need an adapter to bolt everything up. that turbo will spool pretty quick and should pull til redline. check out http://www.homemadeturbo.com for more info
Guest
Posts: n/a
I've checked out homemadeturbo before and I'm pretty well educated in how a turbo kit works and what I need I was just not 100% sure which turbo this was because the guy thats selling it dosnt know either. He just knows its a eclipse turbo. Thanks for the replies though I bought it and I'm gonna try and run a dsm smic, dsm bov, hf header and I'm undecided on my charge pipes so far. I'm shooting for 5-6psi I just need a little more power and I'm on a budget.
