Driver door ajar dome light question.
Old May 3, 2004 | 09:26 PM
huntarrr's Avatar
Default Driver door ajar dome light question.
Here's the deal: I have my dome light (98 Civic) on the setting in the middle so that when you open the door, the dome light comes on. The problem is that the light doesn't come on when the drivers door is open, but it functions properly when the passenger door is open. I have checked the piece in the door jam and that is not the problem. Any other ideas?
Old May 4, 2004 | 08:45 AM
huntarrr's Avatar
Default Re: Driver door ajar dome light question. (97redex)
Old May 4, 2004 | 09:06 AM
huntarrr's Avatar
man you guys aren't much help on this one!
Old May 4, 2004 | 09:21 AM
TurboBumblBee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97redex &raquo;</TD></TR><TR><TD CLASS="quote">Here's the deal: I have my dome light (98 Civic) on the setting in the middle so that when you open the door, the dome light comes on. The problem is that the light doesn't come on when the drivers door is open, but it functions properly when the passenger door is open. I have checked the piece in the door jam and that is not the problem. Any other ideas?</TD></TR></TABLE>
make sure the wire is connected to that black boot looking thing and also make sure it is tightly secured to the car.. if that doesnt work then try just grounding the wire thats attached to the switch in the door, it could be broken and not making contact, ive seen it happen before
Old May 4, 2004 | 09:25 AM
AutoXer's Avatar
Check continuity on the switch with a multimeter as well. I'm guessing it's the switch.
Old May 4, 2004 | 10:20 AM
huntarrr's Avatar
Default Re: Driver door ajar dome light question. (Boostfedb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfedb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">
make sure the wire is connected to that black boot looking thing and also make sure it is tightly secured to the car.. if that doesnt work then try just grounding the wire thats attached to the switch in the door, it could be broken and not making contact, ive seen it happen before </TD></TR></TABLE>
I've gone to honda and gotten a new switch that goes in the door jam and it gave me no luck, so its not the switch. As for the grounding, i'm pretty sure the grounding wire is near the dome light, and there is only one ground for both the passenger and driver's door. So if the passenger door works, it can't be the ground.
Old May 4, 2004 | 10:46 AM
punku10's Avatar
Hey i have the same exact problem and i've tried all the things you said and still have no luck its really annoying so bump for some help for me too...
Old May 4, 2004 | 11:51 AM
huntarrr's Avatar
Default Re: Driver door ajar dome light question. (punku10)
Old May 4, 2004 | 05:00 PM
huntarrr's Avatar
Old May 4, 2004 | 05:11 PM
Emong3's Avatar
Try to remove the switch on the driver's side and unplug the wire.
Then connect the wire to any grounding point and if the light does not turn on, you have continuity problem. You can trace it by using a VOM.
If the light goes on, then the switch may not be getting a ground.
Old May 4, 2004 | 05:44 PM
SOHC4life 96's Avatar
Default Re: Driver door ajar dome light question. (Emong3)
i have a similar problem, my light works when i put it in the 'on' position, but wont turn on when either door is open. i checked the fuses, still good. if someone had a picture of where this stuff is, i would really aprieciate it
Old May 4, 2004 | 06:46 PM
Default Re: Driver door ajar dome light question. (DOHC4life)
take off the light bulb cover and make sure the bolt that holds the light to the roof is tight also.. had that happen to me on my old car and only fixed it cause i was pushing on the light and it turned on..
Old May 4, 2004 | 08:26 PM
huntarrr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emong3 &raquo;</TD></TR><TR><TD CLASS="quote">Try to remove the switch on the driver's side and unplug the wire.
If the light goes on, then the switch may not be getting a ground.</TD></TR></TABLE>
It's not the switch but thanks for that other info.. I'll do it tomorrow
Old May 6, 2004 | 08:30 PM
huntarrr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emong3 &raquo;</TD></TR><TR><TD CLASS="quote">you have continuity problem. You can trace it by using a VOM.
This seems to be the problem... What exactly is a VOM and where can I get one? Thanks.
Old May 7, 2004 | 12:42 PM
huntarrr's Avatar
John Anderson
13
Mar 30, 2012 06:44 PM
SLOENUF
Feb 25, 2011 07:24 PM
lmike6453
Sep 18, 2008 05:21 AM
draperj09
May 14, 2008 08:01 PM
nocable4me
Feb 12, 2006 02:31 AM
