TRANNY is rough and MAY grind...catch point CHANGES?!?!
Old May 3, 2004 | 09:15 PM
Super_Eg6's Avatar
Default TRANNY is rough and MAY grind...catch point CHANGES?!?!
I installed an exedy 3puck (6 springs) set with a ACT flywheel, aluminum...when i blew my reverse on my trans...then i installed this set with a new trans but then the tranny ended up grinding after 2 months (my friend swored it was prefect, he even gave a return) but then i installed another tranny and it is starting to feel rough again like the other tranny. I dont want this one to grind too after awhile of driving....AND sometimes my catch point of the clutch drops very low...
WHY WOULD THE CATCH POINT CHANGE ALL OF A SUDDEN?? is it the clutch or something else.....i switched shift linkage but had no differences...help would be GREAT...thx
Old May 6, 2004 | 10:27 PM
Super_Eg6's Avatar
has anyone heard of or had this problem??? plz help
Old May 6, 2004 | 10:53 PM
id10t
Guest
Posts: n/a
pucked clutchs do that. u have to get used to it
Old May 11, 2004 | 08:49 PM
Super_Eg6's Avatar
naw its not the puck, i ran a ACT 6 puck extreme for 2 years before all this started happening...i have never encounter this problem before...
Old May 11, 2004 | 10:13 PM
triggerX's Avatar
Default Re: TRANNY is rough and MAY grind...catch point CHANGES?!?! (Super_Eg6)
Did you break in the clutch and flywheel before beating on it?
Old May 12, 2004 | 06:10 AM
DaX's Avatar
DaX
Loved
Community Favorite
Rx - Urethane shift linkage bushings and synchromesh.
Old May 12, 2004 | 06:44 AM
Gearspeed-Performance's Avatar
Default Re: (DaX)
First question would be: How do you drive the car? Is the transmission under or overfilled? Is the transmission cable or hydraulically operated? if it is cable check your cable to see if there is any binding. If the transmission is fine for two months then it is not the trans(unless you have a little dark cloud that just doesn't go away). It is either a driver issue or other mechanical parts failure that has to do with the drivetrain.
Old May 12, 2004 | 07:30 AM
Rtype16's Avatar
Default Re: (GearSpeedEF9)
Make sure your slave cyliunder and master cylinder are still okay and not leaking. HTey also might be leaking internally.
Old May 12, 2004 | 07:57 AM
StyleTEG's Avatar
Default Re: (Rtype16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure your slave cyliunder and master cylinder are still okay and not leaking. HTey also might be leaking internally.</TD></TR></TABLE>
Sounds like a clutch/slave problem.
Old May 12, 2004 | 08:27 PM
Super_Eg6's Avatar
i do drive my car ALOT but its not my driving, trust me....my master cylinder did leak but was changed before the lastest tranny was installed.
Since it feels rough like my other tranny, i havent been harsh to it...but a lot of my friends ALSO think its the slave but im not missing any liquid from the master cylinder..what can it be???
Old May 12, 2004 | 09:40 PM
Rtype16's Avatar
Default Re: (Super_Eg6)
Teh slave and the master can leak internally and the fluid level will not change.
Old May 13, 2004 | 05:47 PM
Super_Eg6's Avatar
coo ill change the slave but one more question....with the clutch pedal down, and i put the car in gear and take it back out...then i release the clutch, it makes a "cluck" nosie and i feel a little movement in the shifter..any idea...tahnks for the info
Old May 13, 2004 | 05:53 PM
GSlowR's Avatar
Default Re:
When you say it could be leaking internally how can you find out?? my 2nd and 3rd gears grind every once and a while and i've noticed that my clutch seems to get stuck like 1/3 sometimes and pops out late.. i've bled my lines too..
Old May 14, 2004 | 06:17 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Re: (GSlowR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSlowR &raquo;</TD></TR><TR><TD CLASS="quote">When you say it could be leaking internally how can you find out?? my 2nd and 3rd gears grind every once and a while and i've noticed that my clutch seems to get stuck like 1/3 sometimes and pops out late.. i've bled my lines too..</TD></TR></TABLE>
My brake master cylinder is leaking internally. The way I can tell is by sitting on a hill and holding in the brake pedal. After about 2 minutes the pedal has sunk all the way to the floor and the brakes will no longer hold. I am not losing any fluid though. I guess to test the clutch system, turn your car on, put it in gear [do this on a flat place] and hold the clutch in. If after any amount of time the car starts to grab the clutch, you have a leak, and if you're not losing any fluid, it is an internal leak.
Old May 14, 2004 | 07:25 AM
GSlowR's Avatar
Default Re: Re: (DaX)
and what is required to fix this problem??
Old May 14, 2004 | 08:16 AM
DaX's Avatar
DaX
Loved
Community Favorite
Rebuild or replacement.
Old May 19, 2004 | 10:24 PM
Super_Eg6's Avatar
both have been replaced...i used a jdm itr master cylinder...thats fine right? they are the same right? but my problem is still there...can it be the ACT lighten flywheel?
Old May 28, 2004 | 09:34 PM
Super_Eg6's Avatar
im going to change out my whole clutch soon...i couldnt go in 4th at rev over 8000rpm....that suck ***....wasted money at test n tune
ramos2589
13
Jan 29, 2008 07:57 AM
Asway
Jan 31, 2005 09:14 PM
