Honda S2000 Honda S2000
question on my new 01's gear ratios
Old May 3, 2004 | 08:31 PM
steven975's Avatar
Default question on my new 01's gear ratios
Hello, I just got my '01 and I notice that in 6th, 60mph runs about 3250rpm, 70 about 3750. Is this normal for a stock FD gear. My GSR ran 3500@70, but it had a 4.4FD, albeit a different top gear ratio.
Does my FD appear stock or do you think it has been upgraded?
Old May 4, 2004 | 12:52 AM
evil vapor's Avatar
Default Re: question on my new 01's gear ratios (steven975)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steven975 &raquo;</TD></TR><TR><TD CLASS="quote">Hello, I just got my '01 and I notice that in 6th, 60mph runs about 3250rpm, 70 about 3750. Is this normal for a stock FD gear. My GSR ran 3500@70, but it had a 4.4FD, albeit a different top gear ratio.
Does my FD appear stock or do you think it has been upgraded?</TD></TR></TABLE>
nope, you're running a stock FD:
http://www.geocities.com/fkflee/
did you run a speedo correction device in your GSR to compensate for the different gear ratios and final drive or do the FWD trannys have a different speed sensor pickup point. When going from a 4.1 to a 4.44 or 4.77 or higher gear ratio and not using a speedo correction device, the speedometer will read a higher speed at a given RPM point, so you are going slower than what your speedo tells you. Hence that might explain why you were seeing 70 @ 3500rpms when at 3500rpms you were probably going 60mph or less. That is only true if you didn't use a speed correction device in conjuction with your different final drive ratios.
*edit* as you already know, a 4.10 is a stock final drive for the s2000
Old May 4, 2004 | 05:22 AM
steven975's Avatar
Default Re: question on my new 01's gear ratios (vapor)
actually, the GSR's stock is 4.4.
Old May 5, 2004 | 12:32 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steven975 &raquo;</TD></TR><TR><TD CLASS="quote">actually, the GSR's stock is 4.4.</TD></TR></TABLE> and the stock s2k FD is 4.10.
BeniRacing
Transmission & Drivetrain
61
Oct 25, 2008 04:37 PM
Black R
Mar 28, 2006 05:49 PM
da'ee
Mar 10, 2005 06:54 AM
Nick248
May 30, 2003 05:51 PM
HatchSteer
Nov 22, 2002 06:04 AM
