got the new tranny (installation and syncro question)
Old May 3, 2004 | 08:03 PM
EGRhatch's Avatar
Default got the new tranny (installation and syncro question)
okay so I picked up this 94 ex tranny tonight and the guy said it has a slight grind in 2nd if you slam it into gear... so I knwo it's the syncro.. now he said it only grinds if you "slam" it into gear... this tranny is goign to be on the car for about 3 months until the K gets here so should I go ahead and replace the syncro or do you think some GM syncromesh would be a better solution since it will only be in there for about 3 months??
now my question about installation... do I need to pull the motor or will it just make it easier... and for the clutch I will be using the clutch from my old tranny and I know it isnt put on there correctly because it has a lot of vibration when it is in neutral so where can I get a spline/tool to get it on there correctly... (autozone, pepboys) ??? Thanks a lot
Old May 3, 2004 | 08:35 PM
EGRhatch's Avatar
Default Re: got the new tranny (EGRhatch)
bump cause im going to bed and probably wont find out until tomorrow anyways
Old May 3, 2004 | 09:00 PM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch &raquo;</TD></TR><TR><TD CLASS="quote">this tranny is goign to be on the car for about 3 months</TD></TR></TABLE>
just leave it go. it's not worth the parts & extensive labor if you're only using it for such a short time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch &raquo;</TD></TR><TR><TD CLASS="quote">do I need to pull the motor or will it just make it easier...</TD></TR></TABLE>
no need to do that... leave it in the car. there's plenty of room in a 5th gen. in a 4th gen it's easier to pull the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch &raquo;</TD></TR><TR><TD CLASS="quote">where can I get a spline/tool to get it on there correctly</TD></TR></TABLE>
i think honda has them. but you might be able to get one from autozone. i really don't know, i've only used the tools that come with a new clutch kit.
Old May 3, 2004 | 09:03 PM
99blackcivicSi's Avatar
Default Re: got the new tranny (jwn7)
Get a clutch alingment tool from anywhere really it is a very very very cheap tool.
I would through in some GM syncromesh Friction Modifyed (don't forget about the FM because the other **** is just the same as the Honda MTF) and let it go no point in ripping a trans all apart and doing a sycro when there is no need to.
Old May 3, 2004 | 10:44 PM
5w20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch &raquo;</TD></TR><TR><TD CLASS="quote"> so I knwo it's the syncro.. now he said it only grinds if you "slam" it into gear... this tranny is goign to be on the car for about 3 months
since it only grinds going into 2 when slam then dont slam gears. can you wait 3 months and not beat on it? </TD></TR></TABLE>
Old May 3, 2004 | 11:14 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: got the new tranny (5w20)
yo Brandon....having the vibration at idle has nothing to do with the clutch being alligned. If the mainshaft slid into the clutch disc- which it obviously has, then it is something else. Possibly a loose flywheel or pressure plate.
Be easy on that tranny because you know I'll be asking for it in 3 months
Just run some fresh Honda MTF and you should be fine....no need to be SLAMMING gears anyways...after all, it's only a single cam
Old May 4, 2004 | 01:11 PM
EGRhatch's Avatar
Default Re: got the new tranny (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">yo Brandon....having the vibration at idle has nothing to do with the clutch being alligned. If the mainshaft slid into the clutch disc- which it obviously has, then it is something else. Possibly a loose flywheel or pressure plate.
Just run some fresh Honda MTF and you should be fine....no need to be SLAMMING gears anyways...after all, it's only a single cam </TD></TR></TABLE>
cool... and I wont be smashing around here... every civic I have seen down here has either an LSvtec or an H22 so I'm too scared to race anyone anyway so this thing wont be smashed on... and all I really see are ss camaros (like '76 style) and new cobras... cool well I'm gonna go get started on this pullign this tranny out... yay!
IT GUY
May 17, 2007 10:02 AM
wernhersey
Dec 8, 2006 02:15 PM
civic gtr
32
Nov 4, 2004 06:51 PM
JohnnyM
Apr 2, 2003 10:30 PM
JohnnyM
Apr 2, 2003 10:07 PM
