ecu question
Old May 3, 2004 | 05:39 PM
flatty's Avatar
Default ecu question
can some one tell me how to tell the differents between a ecu for a automatic and one for a manual setup thanks
Old May 3, 2004 | 08:36 PM
limpy's Avatar
Default Re: ecu question (dundalk si)
bump for a good question, not quite sure.
Old May 3, 2004 | 10:06 PM
Mr_CRX's Avatar
Default Re: ecu question (limpy)
which ecu is it? usually you can tell by the numbers on the side. For example, I had a PR3 ecu. part number was something like: xxxxx-pr3-J51. the J51 part tells if its auto or manual.
I found this in a quick search:
in 88-91 ecus (PM6, PR4, PW0, PR3, PM7):
5spd = 000, 001, 002, A00, A01, A10, J00, J001, C01, C00
Auto = J51, J50, A50, A51, 900, 901, A60, C50, C51, X30, A80
92-5 ECUs (P28, P30, P61, P72, P91, P08)
5spd = 000, 001, 002, 003, A00, A01, A02, C00, C01, C02, J00, J01, J02
Auto = J50, J51, 900, 901, 902, C50, C51, C52, A50, A51, A52
96-00 ECUs (P2E, P2P, P2J, P72)
5spd = 000, 001, 002, 003, A00, A01, A03, C00, C01, C02, C03, J00, J01, J02, A11, C11
Auto = A70, A71, A72, A91, A92, C70, C71, C72, C91, C92
from the patterns we can learn the following:
first letter = country of orgin
J = Japan
C= Canada
A=USA
second digit, if 5, 7, 9 then ecu is auto usually
third digit denotes the version/variation
pip9
37
Jul 5, 2015 06:19 AM
hmtcrxsir
Apr 10, 2009 06:13 AM
bullyuly
Mar 9, 2008 11:30 PM
ZC_Power
Apr 13, 2003 10:58 PM
