alright well just did my brakes and tried searching
Old May 3, 2004 | 03:53 PM
integrakilla's Avatar
Default alright well just did my brakes and tried searching
I just did my front brakes and now the pedal goes down further then before. I tried to searching to see If I did something wrong or missed something but I think I left the e-brake up while doing it can that affect anything
Old May 3, 2004 | 03:58 PM
chad's Avatar
Moderator
Default Re: alright well just did my brakes and tried searching (integrakilla)
what does......just did my brakes mean??
Old May 3, 2004 | 04:28 PM
hondawheelwizard's Avatar
WHAT HE MEANS IS STOP BEING VAGUE!
1. FRONT OR REAR?
2. JUST PADS, OR ROTORS, CALIPERS, HOSES, LINES, HARDWARE?
3. HOW DID YOU PUSH THE PISTON BACK INTO THE CALIPER?
Old May 3, 2004 | 04:33 PM
front I mean, and just pads
Old May 3, 2004 | 04:48 PM
foz's Avatar
foz
did you bleed the lines after changing the brakes?
Old May 3, 2004 | 05:01 PM
JDM EJ1 95's Avatar
try bleeding... does the pedal feel spongey?
Old May 4, 2004 | 04:57 AM
Default Re: (JDM EJ1 95)
well its feels like its not to to soft but soft enough to know it its a difference and it goes low. I bleed it but not sure if I did it right (since problem occured ) any tips on bleeding.
Old May 4, 2004 | 10:28 AM
JDMEK1's Avatar
Default Re: (integrakilla)
You don't have to bleed the brakes when changing pads.
1.Make sure the puck is all the way back in the caliper.
2.Once it is all back together you have to pump the brake pedal like 5 or so times to get the pressure back in the lines.
You should be fine after that if everything was installed correctly.
Old May 4, 2004 | 09:08 PM
Default Re: (JDMEK1)
sorry dude but what puck
Old May 4, 2004 | 09:15 PM
blkgsr03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrakilla &raquo;</TD></TR><TR><TD CLASS="quote">I just did my front brakes and now the pedal goes down further then before. I tried to searching to see If I did something wrong or missed something but I think I left the e-brake up while doing it can that affect anything </TD></TR></TABLE>
Did you take the Brake resevoir cover off in the engine bay? if you didnt. i think you need to rebleed your brakes
Old May 4, 2004 | 09:33 PM
2+2Door's Avatar
Can you walk us through the steps you took during ur "brake job"
Old May 4, 2004 | 09:56 PM
jameskersten1's Avatar
Default Re: alright well just did my brakes and tried searching (HeterHsan)
sounds like you got air in your system, figure out how to bleed system and go from there. just replacing pads there isnt any reason to bleed the system but since you did....
Old May 5, 2004 | 05:08 AM
Default Re: alright well just did my brakes and tried searching (jameskersten1)
hmm have to run to work I will lists the steps when I GET BACK thanks guys
adim
Jun 11, 2009 06:33 PM
Kendo88
Mar 10, 2009 09:57 PM
speedfreek128
14
Feb 26, 2009 10:01 PM
smoovekriminal
Apr 15, 2008 06:11 PM
tsjeff
Apr 4, 2003 09:32 PM
